1. plutocadet's Avatar
    I've read reviews on Verizon's support and protect app something or other and it seems a battery drainer. To be concise, to remove it I need to alter its status as device admin. Where can I get to the device admin menu? I've looked in settings everywhere . thanks
    02-21-2014 02:36 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Go to Settings>Security, then scroll down towards the bottom and select Device Administrators. You should then uncheck the app in question, after which you should be able to either remove it (if it wasn't preinstalled bloatware) or hopefully disable it (which isn't always possible with carrier bloatware.
    02-21-2014 02:49 AM
  3. plutocadet's Avatar
    Hey thanks, was able to disable it bit not remove it. Hopefully it saves some battery life .
    B. Diddy likes this.
    02-21-2014 04:57 PM
  1. How does Helium work?
    By ruhban in forum General Help and How To
    Last Post: 07-02-2016, 04:07 AM
  2. Replies: 165
    Last Post: 03-20-2016, 03:17 AM
  3. Replies: 7
    Last Post: 02-25-2014, 03:49 PM
  4. S4 - Auto-disabling Wifi on slow connection <--- How do I disable?
    By Nharzhool in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-22-2014, 10:30 PM
  5. S4 says I have less free space than I do
    By serdrakov in forum Samsung Galaxy S4 Active
    Last Post: 02-21-2014, 09:09 AM
