Results 1 to 12 of 12
    SouthEastNC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default way to send & receive calls via WiFi ?
    Thanks in advance.
    Does anyone know of a cheap way to make and receive calls from my unrooted Droid X using WiFi instead of Verizon? Going to be staying at a mountain house that has wireless internet, but no cell service.
    If there is a way to do this, I'd like to receive the calls from people dialing my normal mobile number. I have Google Voice, I use it for voicemail, never used it for sending/receiving calls - don't know if that might be my best bet? Someone suggested using Google Voice with Sipdroid, but said the calls had a delay.
    Thank you again for any insight!
  2. #2
    grnsl2's Avatar
    Posts
    Global Posts
    100 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: way to send & receive calls via WiFi ?
    I've used google voice but it's tied to another phone number not something like a wifi connection.
  3. #3
    JayMSY's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Check out GrooveIP to see if its what you are looking for. There is. Thread for it in the applications forum.
    Sent from my DROIDX using Tapatalk
  4. #4
    nedqadams's Avatar
    Posts
    Global Posts
    422 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Second GrooveIP. It does use your Google voice number but you can forward your Verizon number to it and it works well.
  5. #5
    renegademoose's Avatar
    Posts
    Global Posts
    332 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Another idea would be to have your Verizon number forward to your Google Voice number while you are up there. Essentially you would be receiving your Verizon calls over VOIP as long as you have the Google Voice app installed.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Awesome, thanks!
  7. #7
    Dubbayoo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I thought that Skype could do that now?
  8. #8
    Rocko's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Skype works nice for me.
  9. #9
    Dubbayoo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The "Skype Mobile" app won't use wifi, but there is another app just called Skype that will.
  10. #10
    Rocko's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Dont use the bloatware Skype Mobile. Install Skype on the market(not the verizon app).
  11. #11
    Nuwan's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default
    Seagate and google voice?
  12. #12
    Nuwan's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default
    oops sipgate
