Launcher Pro uses LESS battery?
droidntn
1,341
88
48
I have had Launcher Pro since I got my Droid in July 2010. AFter the GB update, I wiped the phone and reinstalled all including LP.
I decided to use the stock launcher in the last 2 weeks.
I have to charge my phone a LOT more than when I used only LP.
Anyone else have this happen? I thought LP would use MORE battery?
lemtargatwing
8
It would seem maybe you are using less widgets than before, otherwise the battery usage should be about the same, at least in my case it always has been.
droidntn
1,341
88
48
I don't mind posting my stupidity if it'll help someone else. I had turned my screen on BRIGHT 100%. Once I realized that, it's back to it's normal consumption.
fallingOutOfLoveWfithTech
