Results 1 to 5 of 5
    Default dropped droid x in water HELPPPP
    i dropped my droid x in water, after 4 days in rice it turns on again, everything seems to be in working order (havent tried calling anyone yet) except that it doesnt reconize the battery and wont charge.
    do i need to get a new battery or do i need to suck it up say i lost the phone and pay insurance cost to get a new one?
  2. #2
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    Default Re: dropped droid x in water HELPPPP
    you could get a cheapy battery off ebay to see if it is the phone or the battery...
    Thanked by:
  3. #3
    luvsmobile's Avatar
    Luvzmobile
    Posts
    Global Posts
    165 Global Posts
    Default
    It could be the battery but unless it got extremely wet it's probably the phone. I've observed that a phone that gets wet to the point where rice needs to dry it out, typically dies at some point anyway. In other words it's just a matter of time.
    I do get your apprehension to use the insurance I've had some bad phones from assurion.
    Sent from my SPH-D710 using Tapatalk 2
    Samsung Galaxy Note II
    HTC Evo LTE
    Nexus 10
    Thanked by:
    ima go to a store tomorrow and get a used battery if its the phone im screwed, but if its just the battery i can tough it out till my contract ends this year
  5. #5
    you say you are going to suck it up and say you lost the phone and file an insurance claim. Isnt dropping it in the water covered under the same asurion claim? its for accidental damage. Not sure why you would have to lie about it. If you say you lost it, and kept the phone they kill the ESN so you cant use it anyway.
