Will It Hurt My Phone To Use a Blackberry Charger?
MolecularGraph
635
20
check the sides of them, and if they have the same voltage an milliamp numbers, then no it wont hurt, but otherwise i wouldnt test it.
jdbower
615
59
I like the Moto charger- I keep it in my laptop bag because it's portable. However, I use my BB chargers primarily. You're more likely to blow up an underrated charger than harm the device in most cases but Blackberries don't exactly sip power...
jdbower
615
59
If its micro usb, shouldn't all of that be the same?
The voltage should be in spec, but the current rating may be low. With my Storm I couldn't charge with my wife's car charger when I was streaming music with the screen on- it's possible that a low end Blackberry charger won't put out enough juice to charge efficiently but it's unlikely to kill anything. Then again, if something does go wrong it's finger pointing between a faulty phone or faulty charger so there's more headache.
04redgto
453
7
any usb will be the required 5 volts. Blackberry brand chargers should be 1amp chargers. You can also use mini usb chargers with an adapter. You can get these adapters really cheap online.
Mark_Venture
270
5
mark.cdmaforums.com
to repeat what I posted in another thread on the same topic (but for the INC) -> http://forum.androidcentral.com/droid-incredible/14108-all-usb-chargers-same.html
I can say this...
a PC's USB port is usually spec'd to put out 5v and 500ma.
Chargers I have from my older blackberries, motorola phones, and smart phones which have a USB end on them have 5v output, but 500, 550, 750, 850 and 1000 ma. The higher ma rated chargers do charge my devices faster.
So far, I've been using the same chargers with all my phones since 2007... it hasn't hurt one of my phones yet.
For the phones that have MicroUSB ports on them, I use the Moto SKN6252A adapters, and still continue to use my older chargers at my desk.
I'v done this with my Moto Razrs (v3c and V9M), Moto Q9m, Blackberries (too many to list), HTC VX6900, Moto Droid, Moto Devour, HTC Inc, etc.
ADD: The wall chargers I use today are a mix of Blackberry and Moto chargers that supply 750mA or higher, still use the MiniB to MicroUSB adapters, and I've not had a problem yet.
And I'm using those same chargers with my X
