Tips and Tricks for the Droid X
Vald
Wallpaper Tip
- keeping in mind all 7 home screens, resolution is 960x854
- if you get the crop screen, make it full size by holding down on the orange lines and dragging it to the edges. I usually pick the top line on the box and drag up and it sizes the other parts to fit
- there are some cool 960x854 sized wallpapers (see link below) that other Droid X users have posted (tap and hold on the picture and choose save image to save it (defaults to the download directory on your SD card and will show up in your gallery automatically):
Official Droid X Wallpaper Of The Day! Whats Yours?! - Android Forums
DroidNewb
74
Is there a setting to change when the phone is active like an off peak function so it stops searching during the night while I am sleeping?
Dubbayoo
313
6
I do not get cell service at work and would like to turn 3G/mobile service off and run Wifi only. Wifi easy, turning 3G/Mobile off no clue... please help...
Add the app called Powercontrol. By default the 3rd screen to the left should have a toggle at the top for wifi, bluetooth, 3G and airplane mode. Powercontrol just replaces 3G and airplane mode buttons for data sharing.
themaclady
18
Can someone tell me how to turn off the chirping sound I get every time an email arrives? I have looked in lots of settings but can't find it.
ceriem
450
10
Go to GMail > Press Menu Key and select Settings > Find Notification Settings and select the ringtone you want
exempli_gratia
159
Do you have any potential swype tips? I tried it and just can't get it down.
Not for everyone. Still going back and forth on it myself. But some notable advantages:
  • Shorter than ragural keyboard, so mosre pace left on the screen for the actual text/content.
  • Can still peck away one key at a time, in addition to the swypte gestures.
  • Drag from Swype to 5-key ("F") and get a phone-style number pad.
I disabled the sound on key press, but left the haptic (wish there was a reduced level haptic).
exempli_gratia
159
You can generally toggle the keyboard by press-hold the Menu button.
In Contacts list, the keyboard will narrow down entries with just a few a couple letters.
blunt420
331
6
for you former htc users check out dialer one its like the htc dialer its easy to call people if you have alot of contacts..you can dial by name and number
Speedr117
Active member
Jul 13, 2010
31
How did you turn off the sound on the swype keyboard? Thanks!
adelinachau53674
