Tips and Tricks for the Droid X
rog152
75
Is there a way for the moto clock widget to open the clock and alarm app? If not I do not see how motorola missed that.
rooktdphi
237
25
not sure if any of you have come across this yet, but when your phone is ringing, you can flip the phone to face down and it will swap it to vibrate (great for if you are in a meeting and forgot to silence your phone)
doctorlove316
Retired Moderator
Jun 23, 2010
1,145
25
Yeah, that is pretty cool. There's an option in the settings to turn that on or off as well as double tapping the screen to silence the ringer.
anon(4712533)
64
Ringtone for contacts
go into contacts select the contact you want push menu then edit scroll down and you should see additional info expand that and scroll down and you should see call handling ringtone select the arrow and pick the ring tone you want.
:cool:
jedge
Active member
Jul 5, 2010
36
You can edit Beautiful Widgets Home without deleting/recreating it.
Just tap on the weather portion to go into the extended forecast, then click the Settings button and you can change the skin and/or configuration from there.
Reactions: Rushkiboy#AC
stacyadell
100
4
when typing (swype, swiftkey, multi-touch) and long press the red bulls-eye, a magnifier window pops up of the word under the bulls-eye.
tntdroid
Droiderator
Feb 19, 2010
4,473
615
www.flickr.com
Thanks! Ive been delete/adding for months now. So much better!
heathro1281
190
I don't know anything about the battery tab tip, but I second your nomination of the swype edit tip being the best ever.
Battery tab tip = dont pull the tab off your phone that says "pull" under your battery. Seems kind of oxymoronic.
You just gently tug straight up to lift the battery out.
drkrleitch
