Kacee9
I did figure out how to download the video someone sent me via text and then get it onto YouTube to then post on FB........downloaded the Save MMS app. The video was saved in a folder there. Just an FYI.
I thought that was a 3rd party launcher with 3D app drawer enabled. Correct me if I'm wrong.
That's accurate. I don't think it can do that stock.
Does anyone know how to turn off the camera sounds when taking a pic and starting a video?
Why don't you just enable the option to log into voice mail automatically when called from your phone? This option is in your voicemail option menu then you call in and go into settings menu through voice mail, You wont need anything changed to message *86 call in number.
Correction I just learned that this option isnt on the system any longer, maybe because of the new VVM system.... Sorry, this appears not to be a option any longer..
Ok everyone, I've been trying for a week to do this and even called Verizon and went to the store. Verizon customer support and the store technicians were ubable to figure it out. But, I figured out a workaround: Here you go:
1. Delete the preprogrammed voice mail speed dial entries
2. Edit the voicemail speed dial entry in your contact list to include: *86,,[password]# (do not include brackets, just enter your password)
3. Add a new Voice mail speed dial from the contact you just edited
4. Now, here's the trick. Call your voicemail. When it prompts you to enter your password, take the phone away from your ear. It will then send your password through (you will briefly hear it). And that's it - it works.
I have no idea how or why it works, but it does. I wish it worked as it normally should, and just pass the password along automatically, but it doesn't. It's a shame that Verizon is unable to make this work. This is the best workaround I have found. Let me know what you think.
Hmmm I got it to work with #86 but it only works when I have a waiting voicemail and dial to get . If If I go to the dialer and want to dial it to change a setting it won't work. Strange.
Not for everyone. Still going back and forth on it myself. But some notable advantages:
- Shorter than ragural keyboard, so mosre pace left on the screen for the actual text/content.
- Can still peck away one key at a time, in addition to the swypte gestures.
- Drag from Swype to 5-key ("F") and get a phone-style number pad.
I disabled the sound on key press, but left the haptic (wish there was a reduced level haptic).
I've been trying to find Swype but the website says the beta swype in closed. Does anyone know where I can get it? Thanks in advance.
Thanks I found it already.I guess that was the dumbest question that anyone has asked in here.guess you can tell that I'm a android newbie?In fact, I'm using it now.Very cool but very different.Gonna take some getting use to.
If you want to use your Droid X like a real computer and not be sent to those watered down mobile sites, install the Dolphin HD browser and switch user agent to "desktop"in the settings menu. Works great for me since I hate the touch facebook mobile site.
