Results 1 to 20 of 20
- 07-17-2010, 04:22 PM
Thread Author #1
Droid X Ringer Problems?
Hello,
I'm loving my X, but am wondering if anyone else's won't ring? When a call comes in, the phone will only vibrate. The speaker works... I hear the notification sound (for new voicemail, texts and emails), I can hear media and the speaker-phone works fine.
I'd be interested to know if anyone else has experienced this?
I'm assuming that I've set something wrong--the ringer was working when I got the phone on the 15th. I know this isn't a tech support forum, but here are the details in case anyone is willing to offer suggestions:
I've tried everything I could think of (and I did google it and search the forums, but couldn't find a similar DroidX thread). First, I maxed out the ringer volume using physical buttons. Then, I tried each of the following (one at a time):
In settings --> sound & display:
- verified silent mode is off
- verified ringer volume
- verified phone ringtone is set, and that I can hear the preview
- turned off "double-tap to silence" and "smart profile"
Other things I've tried:
- switched back from Google voice to carrier voicemail
- restarted phone
- pulled battery from phone (and left it out for awhile)
- have called the phone from numbers in my contacts, and numbers that aren't in my contacts
My system version is 1.13.516.MB810.Verizon.en.US.
I give my sincere thanks to anyone who is willing to offer suggestions or maybe point me in the right direction! - 07-18-2010, 04:17 AM #2
My buddys phone had this same problem, he went back to verizon store and they did a hard reset (wipe) and it fixed it. Guy said it may have been app. Since he downloaded so many impossible to know which.
- 07-18-2010, 07:25 PM #3
- 07-19-2010, 05:07 PM #4
- 07-26-2010, 01:53 PM #5
I had this problem and i actually went to settings turned vibrate on,then called my phone and it rang out loud and when i turned vibrate back to off it stayed working. Actually have to go to settings though. It didn't do anything when i turned the sounds off from the shortcut on homepage.
- 07-26-2010, 04:48 PM #6
I have a similar but different issue. My phone ringer plays fine, but my text and email notifications play the first second of the tone then stop.
Ive done a factory reset... and im on performance profile. Vibrate is enabled for all notifications and works as it should. - 07-26-2010, 06:01 PM #7
I've have used the flip over to vibrate feature several times now and all appears to be working as normal.
Galaxy Note II - Rooted - Black Status Bar w/WiFi Toggle - 07-28-2010, 05:10 PM #8
- 07-31-2010, 10:49 AM #9
- 08-03-2010, 01:33 PM #10
I've had the same problem. ringer worked fine the first couple days. then stopped all together. I have reset the phone twice now. It has been working almost perfectly since. I'm still getting the occasional glitch...Getting a call from someone with a specific ring tone and the phone ringing with the default ringer. I was thinking of exchanging the phone for another droid x, but after reading the posts, I can only hope Motorola and Verizon will address the problem. At least we don't have Steve Jobs telling us "Your phone is dropping calls?...Don't hold the phone that way"
- 08-05-2010, 03:28 PM #11
- 08-05-2010, 05:11 PM #12
Music is stored on the SD card. A reset will not affect the SD card.
Get Appbrain - it helps with getting your apps back a little easier. - 08-13-2010, 08:42 AM #13
Umm this is a little different, but my Droid X plays a strange ringer [that isn't even listed as a ringtone in settings] when I receive a call. It's something like "boop-boop-boop-boop...boop-boop-boop-boop" and I've tried manually setting ringers to callers, creating my own ringers, switching the default ringer to a different one... nothing works. No matter what I do it uses this strange default ringer and it's incredibly inconvenient. Ive battery pulled more than once (feel like i went back to BB lol) and it hasnt worked. software bug, maybe?
- 08-13-2010, 09:25 AM #14
Re: Droid X Ringer Problems?
I have had that same boobooop boop problem
Sent from my DX using my fingers. - 08-13-2010, 09:42 AM #15
It's good to hear someone else had the same problem. Do you still have it, or did it go away?
Sent from my DX using my mind. - 08-13-2010, 10:19 AM #16
- 08-14-2010, 12:48 AM #17
I was having the same exact problem with mine. Then I actually saved my ringtones as mp3 files on my laptop and dragged them into my phones ringtone folder that way. They work now, except every once in a while it would play the wrong specific ringtone for a certain person, but never my default ringtone unless it was a contact with an unspecified ringtone.
Now though, it just vibrates. I've tried taking the battery out. I guess I'm going to have to reset it. Has anyone else had any luck with this? - 08-14-2010, 10:07 AM #18
I searched "all" the forums and found a couple of procedures that worked for some people. None worked for me other than the dreaded factory reset. Of course, for me, this involved a trip to Verizon store to transfer my contacts from my old S1 to my X. 1 and 1/2 hours...in the store...
- 08-14-2010, 10:08 AM #19
- 03-29-2011, 06:54 PM #20
Reply
