Results 1 to 15 of 15
    Default gmail problems
    today i am not getting notifications
    new email doesn't appear in the app inbox
    in app can't archive or change labels
  2. #2
    Default
    i'm having the same problem. :/
    did you just update the OS? I think mine started to happen after i did the update.
    Default
    yes i did the update last night but only discovered the problem this morning
  4. #4
    1088933's Avatar
    Androidoholic
    Posts
    Global Posts
    736 Global Posts
    ROM
    AOKP JB 4.1 Franco rr230
    Default Re: gmail problems
    Is the auto sync on?
    Sent from DROIDX using Tapatalk
    OG Droid > Droid X > Atrix
    Galaxy Nexus
  5. #5
    matthewdlyons's Avatar
    Posts
    ROM
    4.1.1 with Sense 4+
    Default
    I received my update this morning, but I haven't experienced any problems with Gmail, nor the Motorola email client. Perhaps try removing the account and adding it back.
  6. #6
    Default
    Got the update a couple hours ago and have not noticed any problems.
  7. #7
    Kegman's Avatar
    Posts
    Global Posts
    224 Global Posts
    Default
    updated last night, havn't received **** since yesterday even before i updated. yahoo or gmail. actually some yahoo, but absolutely no gmail
  8. #8
    bucky716's Avatar
    Posts
    Global Posts
    272 Global Posts
    Default
    menu / refresh and see if it reconnects?
  9. #9
    Default
    I updated and haven't noticed an issue. However, i did have an issue with it not syncing emails before the update. Somehow it had deselected auto sync. So def check that for the sync issues.
  10. #10
    terpitude71's Avatar
    Retired Moderator
    Posts
    Global Posts
    2,164 Global Posts
    ROM
    CodeName Android 1.5.5
    Default
    also check your battery saver as well. if you have a data timeout set, you wont get emails pushed to you when the network shuts off
  11. #11
    lastory's Avatar
    Posts
    Global Posts
    6 Global Posts
    Default
    Quote Originally Posted by terpitude71 View Post
    hmm - I was under the impression that even during a data timeout, push gmail would automatically rewaken the data connection? is that wrong?
    Also just to clarify: Smart Mode gives you the option to set data timeouts for peak and non-peak hrs, does Battery Saver mode automatically put the phone in data timeout if there's no activity for 15 mins?
  12. #12
    Retired Moderator
    Posts
    Global Posts
    2,164 Global Posts
    ROM
    Default
    Quote Originally Posted by jls View Post
    i was under that impression as well, but i can tell you through my experience the past couple of days that a gmail push does not "wake up" the phone.
    and i meant battery manager, not battery saver. but for the record, battery saver puts it to sleep after 30 mins, no peak hour setting. it also lowers your brightness, whereas smart mode uses auto brightness, which i love
  13. #13
    Default
    so i made sure my battery manager didn't specify the peak hours and I turned on push (it was unchecked after i did the update) but it still doesn't push my gmail. I have to manually go in and refresh it.
    I've cleared the data and cache of both the gmail applications and i've removed one of my two gmail accounts, put it back on, and it still hasn't been pushing. :/
  14. #14
    Default
    Im having Gmail issues too...Universal Inbox and push notifications not working. However when I go into the gmail app and manually refresh, then all of a sudden I receive all my new emails at once. The fact that others are reporting same leads me to believe this may be a Gmail issue and not a phone issue?
    Droid X since 7/16/10 Galaxy Nexus since 12/16/11
  15. Thread Author  Thread Author    #15
    Default
    fixed my problem doing a factory reset, which is a pain
    there must be a better way
