Results 1 to 7 of 7
    Default Removing Battery Cover
    I just got my Droid X today. So far I LOVE it!! The only thing is the battery cover is a PITA to remove. I am planning on ordering extra batteries for the phone. How do you remove the cover? Everytime I slide it down it seems like I am going to break the phone.
  2. #2
    Verapakill's Avatar
    Posts
    Global Posts
    220 Global Posts
    Carrier
    CM7
    Default
    I found that you just have to man handle it youre not going to break it
  3. #3
    twindragons187's Avatar
    Posts
    Global Posts
    504 Global Posts
    Carrier
    Stock!!!
    Default
    ^^^^^^_what he said_^^^^^^^
  4. #4
    matthewdlyons's Avatar
    Posts
    Carrier
    4.1.1 with Sense 4+
    Default Re: Removing Battery Cover
    lol I wondered the same as I needed to do take the memory card out. Try gripping the phone by the sides and use both thumbs to slide the cover down. Use the same grip to push it closed.
    Sent from my DROIDX using Tapatalk
  5. #5
    MolecularGraph's Avatar
    Posts
    Carrier
    Swapping them all out
    Default
    Hold the glass, your not going to break it, the plastic is less likely to withstand our manly grips!
  6. #6
    Phil Nickinson's Avatar
    Android Central Editor in Chief
    Posts
    Global Posts
    4,886 Global Posts
    Default
    Try this:
  7. #7
    brandonx1000's Avatar
    rule the air.
    Posts
    Global Posts
    1,312 Global Posts
    Default
    i actually love the battery door design on this much better than most phones on the market
    it holds so well compared to the the moto droid
