1. rinnr1's Avatar
    So I'm using the Android Power Control widget and I don't know what this one icon does.. I'm at work so I can't check the manual
    Anyone know?
    Thanks
    Attachment 2185
    07-21-2010 03:18 PM
  2. cae2685's Avatar
    I believe it's whether your data refreshes... not SMS or MMS, but things like facebook, Google talk, etc.
    I could be wrong, so take that for what it's worth...
    07-21-2010 03:22 PM
  3. rooktdphi's Avatar
    i believe it stops your email as well... basically stops the phone from pulling data (aside from calls/texts as cae2685 mentioned)
    07-21-2010 03:54 PM
  4. bucky716's Avatar
    Exactly. Turn that off and you turn off auto sync so you'll have to manually hit refresh on your email.
    07-21-2010 04:09 PM
  5. moosc's Avatar
    Yes that is sync mode.turn it of data will not sync
    07-21-2010 04:55 PM
