Results 1 to 4 of 4
    Default how to find out what wifi im using
    i just upgraded my router and modem at home with 802.11N instead of g. i know my laptop isnt able to pick up N yet but doesnt the DX have n connectivitly. and if so how do i check to see if its using N or g/b. any help would be great. its showing the the speed is at 65mbps on my X. is that good?
  2. #2
    1088933's Avatar
    Androidoholic
    Posts
    Global Posts
    736 Global Posts
    ROM
    AOKP JB 4.1 Franco rr230
    Default
    Quote Originally Posted by searles_400 View Post
    65 is good lol
    Go to Settings> Wireless & Network Settings> Wi-Fi Settings
    Should show you a list of wifi in the area and if you are connected, which on its connected to
    OG Droid > Droid X > Atrix
    Galaxy Nexus
    Default
    well i did that and like i said it shows 65mbps and that im connected to home. i just wanted to know if theres a way to see that its actually using the N data
  4. #4
