- 07-29-2010, 09:02 AM
Thread Author #1
How do I get the "Verizon Wireless" before calls off the phone?
I have searched the site and can't find an answer.
My phone says "Verizon Wireless" every time there is an incoming call, or when I make a call.
I don't want to hear that. I know I am on verizon, I just want to hear my ringtone, and make my call without hearing that.
How do I get rid of this? - 07-29-2010, 09:31 AM #2
Is it saying "Verizon Wireless" + playing your ringtone? The only setting I can think of that would do something like that is Sound & Display Settings > Call connect. However it onely applies to outgoing calls, and the default sound is not "Verizon Wireless". The other setting is in Call Settings > Caller ID Readout. However, that setting should only apply to incoming calls. Which begs the question, do you have any 3rd party apps installed that could be causing this?
- 07-29-2010, 09:37 AM
Thread Author #3
No app. There is an announcement before every call that says "Verizon Wireless" then my ringtone plays. Then when I make a call the same announcement is made when I hit send.
I can't figgure out how to get rid of it, and it has been on there from the minute I bought the phone.
I never had any phone do this before either.
I'm stumped.
Any help will be appreciated.Last edited by jvanwinkle; 07-29-2010 at 09:41 AM.
- 07-29-2010, 09:47 AM #4
This one really doesn't make sense. There aren't any settings, that I can find or think of, that would cause it to do this. I'm not sure where you bought your phone, but was it definitely a brand new, and never turned on before? I've played with this phone extensively and have never seen any setting that would do that. That said, I would probably do a hard reset, and try again. Out of curiosity, what does it say for "System Information" in the settings > about screen?
- 07-29-2010, 09:47 AM #5
- 07-29-2010, 09:56 AM
Thread Author #6
Yep, definately brand new, out of the box, put the battery in new. I set it up myself in the store.
I like you thought it was my "play sound when call is connected" setting, but it hasn't stopped since I unchecked it.
I may try a hard reset and go from there. Hate to lose everything and start over again but that is getting on my nerves LOL. - 07-29-2010, 10:35 AM #7
It would get on mine too. Does it always come out of the speaker, or does it come out of the earpiece too?
- 07-29-2010, 10:44 AM #8
I found the setting. Go into settings, sounds and display, and turn off roaming tone.
Thanked by: - 07-29-2010, 10:44 AM #9
Could you have a 'beta' phone or something the developers used? They may had the ringtones locked like that for advertising or morale. Thats my only out of left field speculation BS answer I can give
- 07-29-2010, 10:45 AM #10
menu>settings>sound and display> (turn off ) ROAMING TONE!
Enjoy your new phone and have a nice dayThanked by: - 07-29-2010, 04:57 PM #11
- 07-29-2010, 05:13 PM #12
- 07-31-2010, 04:19 PM
Thread Author #13
- 07-31-2010, 05:39 PM #14
- 02-13-2013, 03:14 PM #15
Re: How do I get the "Verizon Wireless" before calls off the phone?
Soooo... I have this problem, but on my Droid X, the option is checked and grayed out.
A few of my colleagues have already dropped Verizon over this. I like the phone and all, but the announcement during meetings is unprofessional. I get complaints about it constantly. - 04-22-2013, 02:21 PM #16
Reply
