Results 1 to 8 of 8
    mikesmith's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Help. Screen won't come on and can't turn off phone
    I've been charging my phone since about 11pm last night through my computer's usb and now at 4pm the screen won't come on.
    I went to check my phone and saw the blue led notification light was solid. Not blinking but solid. I clicked the power button to get the screen to come on and nothing. I clicked the other buttons and nothing. So I held the power button down to turn off the phone and nothing.
    I pulled the usb cable from it and tried hitting the buttons again and nothing. I plugged the cable back in and it said, "droid" and shows up on my computer.
    Is there any way to restart my phone? Do I have to pull the battery? Will it mess my phone up to pull it while it's on?
    My phone hasn't done anything like this before. It was working fine earlier today.
    Thanks.
  2. #2
    Cory Streater's Avatar
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by mikesmith View Post
    Yep, and no. Do you use Handcent?
    mikesmith's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Cory Streater View Post
    Thanks. And no.
    mikesmith's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Looks like I had a missed call, text, and voicemail.
    Maybe the three things coming close together in time caused my phone to mess up?
    I don't know. Seems to be working now. Hopefully it was just a one time thing.
  5. #5
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    When you said it had a solid blue LED, I thought it was Handcent. Anyway battery pulls are an extremely rare occurrence, so if it continues to happen, either exchange it or if you're using a 3rd party app there could be an association there as well.
  6. #6
    thevacantsoul's Avatar
    Posts
    Global Posts
    147 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Make sure you are not running a task manager.
    mikesmith's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by vlade31 View Post
    I am running Advanced Task Killer. Did that cause the problem?
  8. #8
    doctorlove316's Avatar
    Retired Moderator
    Posts
    Global Posts
    2,258 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Possibly. Depending on what your settings were.
    I would suggest checking out this thread if you are interested in keeping ATK on your device.
    http://forum.androidcentral.com/moto...k-killers.html
