There was some really good advice in this article and it was the reason I bought and setup the application "autostarts". I LOVE that application. There are a few apps that sneak through it somehow and I'm still playing with it to try to get them killed since I DO NOT use a task killer app. The only thing that I have done that this article has mentioned was use "autostarts".
I need to point out though (I wish the article's author would have) is that when deleting the bloatware from your Droid X, there have been many know issues that come from this in regards to system updates.
There were multiple reports of people that removed their bloatware, and then when the .604 update was pushed out, they weren't able to get it. The update would download but when it tried to install, it would install fine until it got to one of the removed programs, and then it would fail and cancel the update.
The fix for that was to not just reinstall the bloatware back onto the device, but to reinstall it AND program the bloatware back to "system applications". Just installing them back would not make them "system applications" and they would still fail the update.
Just a heads up since I can already see it now; we get Froyo (finally!) and then everyone comes complaining that their update won't install and it will be because they removed a bunch of bloatware or removed things that they shouldn't have. Since rooting is so easy now, I want to caution everyone that when you are rooted, you have access to a lot of things that shouldn't be played around with.
