Results 1 to 7 of 7
    Default Problem making a purchase on market
    Whenever I try to purchase an app on the droid market, I would get an error when I finish inputting my cc information and click buy now. The error message is:
    "server error has occurred.please retry or cancel.."
    Thank you in advance for the help
  2. #2
    Default
    Try disabling wifi if not in range of a connection or reboot device and then open web browser and make sure web connection is present and then try again, I experienced this issue before but I learned that it was because I had wifi on and wasn't in range of any hotspots and system wasn't going back to default data connection.
    Thanked by:
  3. #3
    Toxa's Avatar
    Posts
    Global Posts
    262 Global Posts
    Default
    I had the same problem. Log in to google checkout from your computer, put in your cc info, and then buy away
    Good luck
    Thanked by:
    Default
    ahh ok, ill try that later.. hopefully it fixes it >.<
    thank you guys
  5. #5
    Cory Streater's Avatar
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Default
    This probably isn't your problem, but it's worth mentioning the Market will not let you use an Amex to purchase apps in foreign currency. Your card will be greyed out in the select payment method pulldown.
    Thanked by:
  6. #6
    Default
    I was having this same problem, and posted about it a few days ago. Logging into GCheckout from a computer and inputting / saving the CC info that way was the only workaround I could find.
    I'm wondering if this might be a glitch in NotBlur.
    Default
    Quote Originally Posted by Cory Streater View Post
    haha, that was exactly my problem. i was trying to use my amex card to purchase something in euro
    thank you very much for that info
