Everytime i take a picture with my droid x camera the people in the picture come out with red eye. Is this just a problem the camera has, or is there a way of fixing this?? Any help with this would be appreciated. Thanks in advanced.
It's a feature to make everyone a droid.....
There are three solutions:
1. Don't use a flash. The issue is that when a flash is close to the lens the light reflects right back, unless you've got a pro camera with an external flash redeye is a problem.
2. Have your friends remove and/or close their eyes when you take a picture. This is often difficult at first, but once you pin them to the ground you'd be amazed at how well a spoon works. Typically this isn't the preferred solution, but some people just deserve it.
3. Many compact cameras that don't have redeye problems solve it through software (there's also some preflash techniques, but those are hard to do with an LED). Which camera application are you running? Have you experimented with any of the others in the market? Have you explored the settings for redeye reduction?
Are you using zoom at all? Try not using zoom as well if so.
Turn the flash off...worked for me
If i turn off the flash the pictures come out pretty dark
