Results 1 to 17 of 17
    Default Problem with red eye in pics, anyone else having this problem??
    Everytime i take a picture with my droid x camera the people in the picture come out with red eye. Is this just a problem the camera has, or is there a way of fixing this?? Any help with this would be appreciated. Thanks in advanced.
  2. #2
    anthonok's Avatar
    Posts
    Global Posts
    110 Global Posts
    Default
    It's a feature to make everyone a droid.....
  3. #3
    bgpasha's Avatar
    Posts
    Global Posts
    431 Global Posts
    Default
    Quote Originally Posted by anthonok View Post
    HAHAHA LMAO!
    To OP, I do have the same problem. so its not just you. wonder if there is a work around it
  4. #4
    jdbower's Avatar
    Posts
    Global Posts
    750 Global Posts
    Carrier
    CM9,Tablet Mode,Nova
    Default
    There are three solutions:
    1. Don't use a flash. The issue is that when a flash is close to the lens the light reflects right back, unless you've got a pro camera with an external flash redeye is a problem.
    2. Have your friends remove and/or close their eyes when you take a picture. This is often difficult at first, but once you pin them to the ground you'd be amazed at how well a spoon works. Typically this isn't the preferred solution, but some people just deserve it.
    3. Many compact cameras that don't have redeye problems solve it through software (there's also some preflash techniques, but those are hard to do with an LED). Which camera application are you running? Have you experimented with any of the others in the market? Have you explored the settings for redeye reduction?
  5. #5
    doctorlove316's Avatar
    Retired Moderator
    Posts
    Global Posts
    2,258 Global Posts
    Default
    Quote Originally Posted by jdbower View Post
    Option #2 FTW?!?! YESS!!!!!
  6. #6
    Duvi's Avatar
    Posts
    Global Posts
    20,036 Global Posts
    Default
    Are you using zoom at all? Try not using zoom as well if so.
  7. #7
    Default
    Even my Nikon D90 will end up with red eye pics. It happens to the best of us.
  8. #8
    Default
    Turn the flash off...worked for me
  9. #9
    Default
    Its the flash being reflected back through the eye (cats have terrible red eye because they intentionality reflect light back so they get more light in their eyes to see better at night) so if you turn off the flash, no red eye. the other thing is if you arent looking directly at the camera or you can get it off centered you can reduce it but its just a bad effect that, like jdbower said, its very difficult to work around with these led flashes.
  10. Thread Author  Thread Author    #10
    Default
    No where would i find the red eye reduction settings??
  11. Thread Author  Thread Author    #11
    Default
    Quote Originally Posted by Duvi View Post
    no i dont zoom and it will still have red eye
  12. Thread Author  Thread Author    #12
    Default
    Quote Originally Posted by kj11aw View Post
    If i turn off the flash the pictures come out pretty dark
  13. #13
    Default
    The real question is where is the aapp to remove red eye
  14. Thread Author  Thread Author    #14
    Default
    I am nowusing the pic say app to remove the red eye, works like a charm. Just sucks the droid doesnt bring it built in and if it does i couldnt find it for the life of me.
  15. #15
    Default
    Quote Originally Posted by Reydelgado0320 View Post
    Play around with the exposure settings...in low light I'm going with a 2 or 3...outside or in better lighting conditions I usually use 0. This should work
    stillblood likes this.
  16. #16
    Default
    I have the same problem. Every. Single. Picture has red eye. The camera has such a good quality, but if you use the flash on people, it seems you are screwed. It doesn't matter what the lighting, distance, zoom, nada. anyone have any real suggestions?
  17. #17
    Default Re: Problem with red eye in pics, anyone else having this problem??
    Unfortunately, the DX doesn't have any red eye prevention built-in, so they are pretty unavoidable if you are using flash.
    I usually share such pictures with red eye to Picasa, which has the worlds best auto red eye removal tool. Of course that means using your PC to process the red eye removal.
    If there are any Android apps that can do the job in the DX, I haven't found them yet.
    Sent from my DROIDX using Tapatalk
