1. milo12's Avatar
    How can I add numbers to a phone number that I can use when asked to input them? For example if you use Goto Meetings ( conference call service) You call a phone number, then you are asked for the access code and then for the Meeting ID.
    Is there a way of adding all these numbers to a contact so I only have to dial a contact and have the numbers either enter when I hit a button or automatically enter?
    08-11-2010 03:14 PM
  2. Adiliyo's Avatar
    I think you can add a pause (p) to a number and then input the rest and it should do what you want
    08-13-2010 02:13 AM
