Results 1 to 2 of 2
    CavemanOOGA's Avatar
    Posts
    Global Posts
    313 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Quick question regarding the Social Networking side of things...
    Is it possible to change how often the MotoBlur widgets/apps update or pull data? It seems to be set for every 30 minutes, but i would like to make it pull data faster if possible.
    Is there anyway to do this? Like a setting that i may have missed?
    Sent from my DROIDX using Tapatalk
  2. #2
    terpitude71's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CodeName Android 1.5.5
    Default
    sadly, no. there is no option that i have found that will allow you to adjust this. the only options in the phone are for the ability to have it stop pulling data after a set period of time of non-use.
