Hello everybody,
Sorry if this has been discussed elsewhere - I couldn't find a thread with the same problem.
I had my phone plugged in to the wall the other night and then my alarm went off I picked it up and it shut off. After that it wouldn't turn on anymore.
When I plug it into the computer or the wall, nothing happens, except the little white light next to the USB port comes on.
After a while I found out that by fiddling with the battery and the wall charger cable (no reliable steps to reproduce), I can have the charger plugged in without the white light being on and when I insert the battery afterwards, the phone will power on (once in a while).
When it's on it seems to be working fine, but as soon as I pull the cable, it dies again. When it is running, the red notification/charging light is on, as well as the white USB one.
The problem is it says the charge is at 5% and this will not change, no matter how long it has been plugged in.
What else I have tried:
- different battery (OEM)
- different charger (OEM, 750mA)
- factory reset
- leaving it plugged in/charging forever
Does anybody have any idea?
Thank you!
- factory reset
Thank you!
