Results 1 to 5 of 5
- 08-22-2010, 02:56 AM
Thread Author #1
2.2 lock screen problem
Anyone having an issue with the basic lock screen not working on 2.2? There isn't even an option check box for it. The only time I can get it to work is if I do a pattern lock or something of the sort but then I have to deal with both. Anyone else have this?
Sent from DROIDX using TapatalkOG Droid
> Droid X
> Atrix
Galaxy Nexus
- 08-22-2010, 09:25 AM #2
Yep I can't even disable the lock screen. Which I miss. Have to remember this a leak and not official release
- 08-22-2010, 09:50 AM #3
Yup. I, too, have no basic lock screen. The only way for me to get the slide to un- lock screen is to set either a pattern, pin, or password lock. Kind of sucks. Before I upgraded to 2.2, I had no lock screen turned off in 2.1. I wonder if that is why I have no unlock screen in 2.2.
- 08-22-2010, 10:21 AM #4
I had the same problem and did a factory reset and that fixed it.
- 08-22-2010, 10:43 AM
Thread Author #5
OG Droid
> Droid X
> Atrix
Galaxy Nexus
Reply
