Results 1 to 7 of 7
- 09-07-2010, 02:18 PM
Thread Author #1
Disabling/customizing the double tap home
So the fact that the choices for the double tap home button are severely limited really annoys me, doubly so since you can't even disable it. I have my X rooted, so given that I was wondering if anyone knows of a way to either disable or get further customization options for it. Anyone?
- 09-07-2010, 02:37 PM #2
LauncherPro has opitions for Do nothing, Open/close screen previews, open/close app drawer, open/close notifications, and show/hide status bar
Edit: I'm an *****. Those are the single-press options.Droid X
Samsung Galaxy S3 - CM10 - 09-09-2010, 08:27 AM
Thread Author #3
- 09-17-2010, 04:24 PM #4
- 01-26-2011, 07:19 PM #5
- 01-27-2011, 08:20 PM #6
It sounds like your settings.db is fairly different from mine. Mine has android_metadata, settings, and sqlite_sequence. If you haven't already you might want to take a look at 'system' to see if it has the settings. Otherwise you might have to try exploring other directories under /data/data, especially ones with motorola or settings in the name. I originally found this by just poking around in directories that looked like they might contain the information I was looking for.
Here are the first few entries of my settings database, might help you find the right one:
test_attribute, eri_alert_sounds, eri_text_banner_software_update_alert. - 01-29-2011, 07:18 AM #7
Reply
