Results 1 to 10 of 10
    Arelunde's Avatar
    TECHFAN
    Posts
    Global Posts
    1,528 Global Posts
    Default Is there any way to block incoming texts?
    Someone has my X's number and is sending text messages in another language. How can I block these incoming texts? (... besides just deleting them as they arrive.)
    Always learning ...
  2. #2
    Default
    call verizon, they should place a block on the number for you.
    I did the same for my ex =)
    Thanked by:
  3. #3
    Default
    Vtext.com
    Create a login and then add the number.
    I think you can have 5 for free.
    Beyond that you need to add usage controls for $4.99 a month.
    Thanked by:
  4. #4
    Default
    Log onto my verizon.
    You can block text and calls for upto 5 numbers for free
    Thanked by:
  5. #5
    Default
    I also think Handcent has a blacklist thing that blocks unwanted numbers.
    Thanked by:
  6. #6
    Default
    I use Call Blocker Elite, it does well with blocking calls and it reports to block text as well (But havent used text feature yet)..
    Check it out :
    Samsung S3
    Time to feel the POWER...
    Thanked by:
  7. #7
    Default
    Quick search and found this for free... Call&SMS Filter at
    Samsung S3
    Thanked by:
  8. Thread Author  Thread Author    #8
    Arelunde's Avatar
    TECHFAN
    Posts
    Global Posts
    1,528 Global Posts
    Default
    Thank you all! Much appreciated!
    Always learning ...
  9. #9
    cae2685's Avatar
    Posts
    Global Posts
    727 Global Posts
    ROM
    Stock
    Default
    The downside to an app-based solution is that I believe the texts still technically get delivered to your phone, and then the app deletes them.
    Just something to consider if you're on a limited texting plan. Calling verizon to block the number doesn't cost anything, I had them block a former roommate who kept calling me just to harass me.
    Droid X
    Samsung Galaxy S3 - CM10
  10. Thread Author  Thread Author    #10
    Arelunde's Avatar
    TECHFAN
    Posts
    Global Posts
    1,528 Global Posts
    Default
    You are right. Tried an app. Blocked text, but it was still there on Verizon. Waiting to se if texter gets tired if no response. If not, will block on Verizon.
