1. McTavish's Avatar
    So here's the backstory...I haven't used my X in a while,it was running on MIUI ICS but...after a month of inactivity I need to use it again.I power back on and it says, 'Bootloader 30.04" "Battery ok,ok to program". Well I look it up and find I need to flash a new rom, I power on while holding down the home button and get "Android system recovery".So far so good.I download the latest stock android and try to apply the update and it comes up with the "error in tmp/sideload/package.zip.......etc. my only problem is that the computer won't recognize the X and it won't reboot so I'm stuck working with the Android system recovery and bootloader 30.04......What can I do ?
    01-05-2014 10:02 PM
  2. sd_shadow's Avatar
    droid x updates can only update stock firmware
    you need to flash a sbf using rsd lite, sbf_flash, or ezSBF
    links in my list
    sd_shadow's [Collection] of Links for: Droid X (MB810)
    Sent from my DROIDX using Tapatalk
    01-05-2014 10:23 PM
  3. McTavish's Avatar
    So I tried flashing stock ROM from the SD and it failed so I'll try using rsdlite and see what happens
    Sent from my Nexus 7 using AC Forums mobile app
    01-06-2014 11:25 AM
  1. Replies: 21
    Last Post: 08-16-2014, 07:48 AM
  2. pop up notifications?
    By maulpauh in forum AT&T LG G2
    Last Post: 01-12-2014, 09:38 AM
  3. How To Delete/Hide Old Calendar Events on Galaxy S4
    By music_man185 in forum Samsung Galaxy S4
    Last Post: 01-05-2014, 08:27 PM
  4. Help! I deleted my lock screen accidentally
    By cag78granger in forum Samsung Galaxy S4
    Last Post: 01-05-2014, 08:03 PM
  5. Replies: 2
    Last Post: 01-05-2014, 07:58 PM
