1. Marc Jenkins1's Avatar
    Had 2.3.4 flashed cm 7 gummy nex worked great then I went into rom toolbox and tried to change my pull down menu background all this stuff kept popping up saying blah blah blah as stopped so I just pulled the battery and now when I turn on it goes into a blank screen after the M logo so I went into basic recovery and it won't reflash the rom nor the backup I made for it and I have no idea how to get into cwm from here kinda new at this so please helpppp!!!! Also if anyone has the correct sbf for 2.3.4 it would b great as all the ones I've found on the web don't work
    03-10-2014 10:28 PM
  2. sd_shadow's Avatar
    Once you lose the ROM you lose access to cwm, unless you had already installed a bootmenu like in my list
    [HOW TO] Install/Use Droid 2/X/3 Bootstrap
    But you will need to flash original firmware/SBF
    Using RSD Lite to flash a .SBF to restore (Stock Rom)
    on Droid X (Shadow-MB810)
    Sent from my Amazon Kindle Fire using Tapatalk
    03-10-2014 10:37 PM
  3. Marc Jenkins1's Avatar
    How can I get my computer past trying to " download correct drivers" so that it will read my phone?
    03-11-2014 04:40 AM
  4. Marc Jenkins1's Avatar
    I also have a dx2 that won't go past the "m" dual core screen after I tried to flash a rally big rom I forget it was like cm alpha jelly bean or something
    03-11-2014 04:43 AM
  5. sd_shadow's Avatar
    see my Install Drivers/ checking drivers
    use the DX2 sbf
    How To Flash a SBF/ (Firmware) Using RSD Lite For the DX2
    Edit: and always Verify that your downloads are complete with MD5/SHA-1 Hash Checksums
    03-11-2014 06:01 AM
  6. Marc Jenkins1's Avatar
    03-11-2014 02:52 PM
  7. sd_shadow's Avatar
    Bad link?
    Yes, fixed link Verify that your downloads are complete with MD5/SHA-1 Hash Checksums
    03-11-2014 09:13 PM
  8. Marc Jenkins1's Avatar
    Is there a AOL or zip I can download from 4 shared that's works like framaroot to root my dx2? I used ur link and got it running still getting a bad error on bootloader for Dx though
    03-12-2014 08:12 AM
  9. sd_shadow's Avatar
    No, you can downgrade with 2.3.4 sbf and use pete's root tooos
    Use 2.3.4./4.5.621 sbf
    Sent from my XT862 using Tapatalk
    03-12-2014 08:43 AM
  10. Marc Jenkins1's Avatar
    So I used romtoolboxlite to try and change framework animations on my dx and it messed with my rom and I had to sbf all over again but it also messed with parts of my LCD display. Like it looks like parts of the screen are fried idk its weird just wondering if anyone ever had the same issue
    03-21-2014 01:07 PM
  1. Help...which phone? (Moto X, Sony z1 Compact or Nexus 5).
    By Lensbabyd in forum General Help and How To
    Last Post: 04-14-2014, 08:17 PM
  2. Please Help, Unlocked S2 Wont Connect to Wifi!
    By Ally Bell in forum Samsung Galaxy S II
    Last Post: 03-11-2014, 12:38 AM
  3. Help...need a decent ROM for my PT7510
    By auzziebob in forum Samsung Galaxy Tab 10-inch
    Last Post: 03-10-2014, 06:24 PM
  4. Need help with bootloaders
    By Headcase_Fargone in forum AT&T Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 03-10-2014, 05:58 PM
  5. HTC One Root Fail PLEASE HELP
    By Deron Buske in forum HTC One M7
    Last Post: 03-10-2014, 05:53 PM
