Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By dwa2
    Default Beeping While On Phone Call (Not An Incoming Message!)
    So when I am on a phone call, I will get a constant beep every 10 seconds. It is not an incoming SMS or Email or anything like that. It is just a continuous beeping pattern. I tried uninstalling every app I've installed since it started and it's still there. Any ideas?
    Storm 1 ----> Droid X
  2. #2
    matthewdlyons's Avatar
    Posts
    ROM
    4.1.1 with Sense 4+
    Default
    My wife has been complaining that she's hearing a beeping, which she thought was an incoming call, but no one was there. She thought maybe it was a notification for incoming text messages or voicemail. She's out of town, but said she was making some adjustments to notification sounds. I'll let you know if that works.
    Thanked by:
  3. #3
    lsmunoz's Avatar
    Posts
    Global Posts
    312 Global Posts
    Default
    Have you checked to make sure you are not in an extended network? You may have your roaming tone turned on.
    Dumb phone -> BB8830WE -> BB Curve 8330 -> Incredible -> DROID X ----->Galaxy S3
    Thanked by:
    Default
    Definitely not roaming.
  5. #5
    jdivers03's Avatar
    Posts
    Global Posts
    60 Global Posts
    Default
    Is it a quick double beep every ten seconds? I've had the same problem ever since updating to Froyo. I've read up about it online, and... it's not necessarily great news. Powering the phone off and back on seems to be a temporary solution. The first few times I power cycled the phone, it went away for an hour or two. Knock wood, after the last power cycle, I haven't gotten it for a few days. A complete factory reset seems to work for some people, too.
    Good luck...
  6. #6
    Posts
    ROM
    4.1.1 with Sense 4+
    Default
    I had my wife power cycle her X. She also changed the notification for text messages and hasn't had a problem since. [knocking on wood]
  7. #7
    Default
    I had it too. A battery pull seems to have fixed it.
  8. #8
    BigGA's Avatar
    Posts
    Global Posts
    3 Global Posts
    Default
    battery pull seemed to fix mine. I was trained by Lack Berry
    Default
    Seems like we all have the same problem and it seems like it's yet another Froyo bug. I rebooted and I haven't hears the beeping since. But I've only made 2 phone calls.
  10. #10
    Default
    See this thread from the Motorola forums:
    Sent from my DROIDX using Tapatalk
  11. #11
    xelhabb's Avatar
    Posts
    Global Posts
    204 Global Posts
    ROM
    3.0.8-gaaa2611, unlocked
    Default
    This very issue has been discussed frequently on the Motorola Owner's Forum which everyone here should join.
    The problem was recreated by someone using the search function to find a Google contact.
    Most of the time the problem is fixed by a battery pull.
    Nextel Flips > Motorola Slider > Blackberry Storm 9530 > Motorola Droid X > Galaxy Nexus
  12. #12
    Arelunde's Avatar
    TECHFAN
    Posts
    Global Posts
    1,528 Global Posts
    Default
    There's another possibility - that you need to do a *228 / 2 (if you are on Verizon) - the roaming update. It locates the nearest cell towers to wherever you are, improving your reception. If you move around a lot geographically, doing this update periodically is a battery saver, as well... Phone portion doesn't have to work so hard to get a signal.
    Always learning ...
  13. #13
    Default
    The only time mine has done this is when I have the alarm or timer set. Maybe a calendar reminder too
  14. #14
    Default
    My x has done the same thing twice now since upgrading ...a beep during a call that sounds like an incoming call, then the phone becomes unresponsive and, although it appears the call has terminated, the other party can still hear you, but you can't hear them.
    Bouncing around a few screens made the call reappear this last time.
    Strange ...
  15. #15
    Default Re: Beeping While On Phone Call (Not An Incoming Message!)
    Ok guys have a look into this.
    Go to your settings.
    Call
    Call Alerts
    Call Status Tones
    Uncheck minute minder if there is a check in that box and the beeping during calls should stop
    Regards
    Ghostflyer
  16. #16
    dwa2's Avatar
    Posts
    Ghostflyer is 100% correct. His solution will solve your problem. Remember to remove the minute minder check.
    The Slide_Masta likes this.
  17. #17
    i Agree i had the same problem with my Samsung Galaxy S4 and the problem is now solved... Thanks buddy
    So happy to be an android now lol good bye Symbian...
