Results 1 to 14 of 14
    matrix2004's Avatar
    Posts
    Global Posts
    1,671 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Droid X EXTREME BASS option.
    I just came across it. It actually gives music a little bass. Nice.
  2. #2
    TurboCam's Avatar
    Posts
    Global Posts
    450 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    found it where? what menu is it under?
  3. #3
    DroidRage79's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    yeah, now that you've piqued our interest where is this option to be found?
  4. #4
    Verapakill's Avatar
    Posts
    Global Posts
    220 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM7
    Default
    Im also interested about this. Is it an app or just an option?
  5. #5
    BrianTX's Avatar
    Posts
    Global Posts
    139 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Settings/sounds/media effects or something similar
  6. #6
    Arelunde's Avatar
    TECHFAN
    Posts
    Global Posts
    1,634 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Settings> Sound > Media audio effects > wired stereo devices OR phone speaker
    In wired stereo devices > enable audio effects ... then select profile settings
  7. #7
    EinZtein's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Settings Sounds Media Audio Effects
  8. #8
    dvader's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I think it just muffles the sound more than anything
  9. #9
    Verapakill's Avatar
    Posts
    Global Posts
    220 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM7
    Default
    Didnt make much of a difference but it sounds better
  10. #10
    Verapakill's Avatar
    Posts
    Global Posts
    220 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM7
    Default
    I found that the best sound is
    Effects Profile > Custom
    Surround > Off
    Equalizer > Balanced
    Lightninrod likes this.
  11. #11
    dubge's Avatar
    Posts
    Global Posts
    1,384 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Always changing
    Default
    I must be going def, I didnt notice ANY difference in ANY settings
  12. #12
    Verapakill's Avatar
    Posts
    Global Posts
    220 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM7
    Default
    I was using Bose headphones turned up loud the settings I used made the music sound clearer
  13. #13
    DaRkL3AD3R's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by SHEEPDOG View Post
    Surround > Off
    I can second this. Basically, false surround sound virtualization will ruin almost all of the audio you hear always. What Sheepdog suggested is what I found to be the best choice for music, games videos you name it.
  14. #14
    Clemsonpablo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I'm willing to bet that most headphones, and possibly stereo systems you're using don't produce bass very well anyways, so this is going to do little for you. Lots of people claim that using EQ settings on the phone eats extra battery also...
