Results 1 to 5 of 5
    Default Wi-Fi Tether-HELP
    Ok. here is the situation. I have a Motorola Droid X. Rooted and installed wireless tether for root users from the market. I turn it on and it recognizes and connects with my computer. BUT it shows that there is no internet access in my connections icon on the toolbar. I have even changed the ssid because i have heard tat fixes it sometimes, but to no avail.
    I need someone with experience to tell me what i am doing wrong please.
    Thank you!
  2. #2
    Default
    i too have this same problem so hopefully someone can help us......
  3. #3
    Default
    I had the same problem with Barnacle on 2.2 until I enabled the "Skip wpa_supplicant" option in settings... now it connects just fine
  4. #4
    Default
    Where is the skip wpa_supplicant option?
  5. #5
    Josh44's Avatar
    Posts
    Global Posts
    129 Global Posts
    Default
    You can check it in settings within the app itself.
