Results 1 to 10 of 10
    Default My Vibration Has A Different "Sound" To It
    All of a sudden my X vibrates differently. It's not as crisp as it used to sound and feel. I haven't changed any settings or anything. Any ideas?
    Storm 1 ----> Droid X
  2. #2
    jyoung's Avatar
    Posts
    Global Posts
    67 Global Posts
    Default
    I noticed the same thing yesterday and it was after the update.
    Default
    OK guys, is this an update thing? Is everyone noticing this?
  4. #4
    revwill's Avatar
    Posts
    Global Posts
    245 Global Posts
    Default
    Quote Originally Posted by miamifin33 View Post
    I believe it is.
    Sent from my DROIDX using Tapatalk
  5. #5
    Default
    This changed for me when I updated to group originally. Its actually the duration of the haptic feedback vibration. I don't know how to change it with the default keyboard, but if you use SwiftKey keyboard you can manually change the length of vibration for your keyboard so that it's closer to what it used to be. Personally I like the shorter haptic feedback... feels crisper to me.
    Default
    The haptic feels the same to me, I'm referring to notification vibrations.
  7. #7
    Bravozero's Avatar
    Drroooiiiiddddd
    Posts
    Global Posts
    477 Global Posts
    ROM
    Sense 3.5
    Default
    +1, it feels like when I get a call or a message, the vibration starts off soft and drastically gets stronger. I wonder why Motorola changed this.
  8. #8
    Default
    definitely different. i wonder if this will wear on the vibrating mechanism quicker.
    Default
    Quote Originally Posted by Bravozero View Post
    That's a good way to describe it.
  10. #10
    Default
    .....I wonder why Motorola changed this.
    My guess is it is just a feature to be able to ensure the vibration is felt if in a pocket or something. I have had times before when I have accidently left the phone on vibrate after work and not felt a call come in while in my front pocket while in the car because of the vibration while driving. Alternating the strength of the vibration could make it more detectable.
    Of course I may just be talking out of my a$$.....
    "They don't think it be like it is, but it do." -Oscar Gamble
    Droid X (Liberty 3 v2.0)
    Droid Incredible (CM 7.2.0 RC1)
    Nook Color w/ 8GB N2A card
