Results 1 to 12 of 12
    Stang04GT's Avatar
    Posts
    Global Posts
    58 Global Posts
    Default Phone is lagging way too much
    For the past couple of days my droid x has been getting very laggy. I have done numerous restarts and it is good for a few hours then becomes laggy once again. Today the battery went to down to 40% after 2 hours off the charger. I didn't make any calls, only like 30 or so text messages and I loaded up 2 webpages. I hate to say it but my blackberry storm 2 never became this laggy so quick. I have uninstalled any app tat I hve downloaded the past week but that didn't help any. What can I do to fix this?
  2. #2
    kajii's Avatar
    Posts
    Global Posts
    407 Global Posts
    ROM
    AOKP, Stock
    Default
    Root and download Cache Cleaner
    Sent from my DROIDX using Tapatalk
    Stang04GT's Avatar
    Posts
    Global Posts
    58 Global Posts
    Default
    its rooted using z4root. I will download and try cache cleaner.
  4. #4
    davidnc's Avatar
    Posts
    Global Posts
    5,624 Global Posts
    ROM
    Nexus(AOKP-jb_4.2.1)
    Default
    Even tho I haven't noticed lag , I like keeping OS operating smooth ,cache cleaner looks user friendly so gunno test it too
    Sent using TaPaTaLk
    SGSIII : White 32 gb model with 32 gb sdcard
    RoM : CleanRom 5.5.1_ jb
    Kernel : n/a
  5. #5
    rjmlakota's Avatar
    Posts
    Global Posts
    63 Global Posts
    Default
    I would give this a try. I was having issues when typing. The keyboard was VERY laggy. This fix helped. I suppose it may help with your laggy phone too.
    http://forum.androidcentral.com/moto...w-reponse.html
    RJ
  6. #6
    Default
    ok, so this is my issue. Rooted phone a few days ago, great. Did the update yesterday, alright. Phone has been lagging like crazy. And the superuser permissions that I had set up on OverClocking and SetCPU are gone and the apps are READ ONLY. So I'm stuck. Do I Unroot then root, or just root it again?
  7. #7
    kentusmc's Avatar
    Posts
    Global Posts
    332 Global Posts
    ROM
    CyanogenMod 7.1 RC 1.2
    Default
    Try a different Rom, I found that once I installed Apex and overclocked my X it runs a lot better
  8. #8
    Default
    Sometimes a bad file/filesystem on your memory card can cause a boatload of problems/lag/freezing/reboots.
    If you have a spare micro sd card, you can put it in your device and see if the problem goes away, if you don't have a spare card, take the sd card out of the device and see if the problem(s) go away with the card removed.
    If the problem seems to be the card, then back up your files from your original card to your PC and reformat the card in the device. Then move your folders/files back to your card starting with the essential folders/files first, then test. Continue to restore files/folders back to your card until you find a bad file, or all the files are back on the card.
    a little obsessive...
  9. #9
    Default
    I've been having the same problems. I thought it was the ROM i was running, SBF'd to get the update applied correctly, and am still having the lag issues, and at this point I'm running 100% stock.
  10. #10
    Default
    Check out your sd card as detailed in my post above.
  11. Thread Author  Thread Author    #11
    Stang04GT's Avatar
    Posts
    Global Posts
    58 Global Posts
    Default
    Thanks for the replies
  12. #12
    Default
    I have been noticing lag since the update
