1. rpmm70's Avatar
    Is there a way to turn off the sound for when the camera focuses? Even with my phone in vibrate or silent, it still goes off
    Sent from my DROIDX
    12-17-2010 12:41 PM
  2. laker_hockey's Avatar
    SilentSnap Free works very well for me.
    12-17-2010 01:11 PM
  3. wildman's Avatar
    Nice find, I didn't even know this existed
    12-17-2010 01:17 PM
  4. tntdroid's Avatar
    You taking sneeky pics. Naughty naughty. I use vignette. No sounds and tons of extras. I replaced the stock camera with it.
    Sent from my DROIDX using Tapatalk
    12-17-2010 01:43 PM
  5. tntdroid's Avatar
    If running apex 1.3.1 you can also run terminal and type su sound -d that will kill it too.
    12-17-2010 01:50 PM
  6. jumpinghooligans's Avatar
    Little known fact, the focus beeps are considered an 'alarm' sound. If you want to take a quick picture silently all you have to do is silence your alarm volume, no apps needed.
    12-17-2010 03:17 PM
  7. greydarrah's Avatar
    If you're hearing any camera sounds when you have your phone in silent mode, go into your alarm clock app and uncheck the box that says something about the alarm working when in silent mode. You'll be totally stealth.
    While there are plenty of good reasons to have your camera be silent, be prepared for the perv police to chime in at any minute to tell you all the laws and reasons about why your camera is supposed to make sounds.
    Silence is golden.
    12-17-2010 03:48 PM
  8. Arelunde's Avatar
    This didn't stop the shutter sound on my X. Hmmm.
    12-17-2010 04:40 PM
  9. tntdroid's Avatar
    Turn ringer vol off or vib. That kills shutter.
    12-17-2010 05:14 PM
  10. Mudvayne622's Avatar
    oh you beat me to it.
    12-17-2010 05:27 PM
  11. rpmm70's Avatar
    Thanks for the tips. I am going to try out Vignette for a bit before I buy it. I have some family visiting this weekend that want to check out some museums and now I don't have to worry about my phone beeping every time I want to take a picture.
    Sent from my DROIDX
    12-17-2010 05:29 PM
  12. Mbaverizon#IM's Avatar
    that cost!!!!!
    12-17-2010 09:56 PM
  13. wildman's Avatar
    The alert made by camera is tied into the alarm volume, so the only way for you to disable is to turn the alarm volume all the way down (If you do not use alarm this shouldn't be a issue). Goto Setting > Sound > Volume > Uncheck "Use Incoming Call Volume for Notification and then turn Alarm all the way down..
    12-18-2010 01:34 AM
  14. Chris Kerrigan's Avatar
    That is such a strange thing to tie it to. You'd think it'd be connected to the Media volume...
    12-18-2010 02:17 PM
  15. wildman's Avatar
    I agree but keep in mind with the option checked it would share the Notification alert volume..
    12-18-2010 02:21 PM
