Page 1 of 3 123 LastLast
Results 1 to 25 of 70
    pnico's Avatar
    Posts
    Global Posts
    398 Global Posts
    Default pls help..urgent
    guys,
    seems that I didnt make a backup..if I did where would it be on the sd card?
    if I didnt make a backup of the rom that came preloaded then I have no choice but to use it rooted... would prefer not to, but if I have no choice then Im screwed..
    in that case, I would like to try apex..the more stable system..
    the problme seems that droid x bootstrap doesnt run when I hit bootstrap recovery..
    so how am I to load this new rom?
    thank you
    Phil
  2. #2
    Smitty_82's Avatar
    Android Addict
    Posts
    ROM
    ICS / Stock
    Default
    Ok Phil, we can get you up and running. First off is the Apex zip downloaded and on the root of your SD card?
    pnico's Avatar
    Posts
    Global Posts
    398 Global Posts
    Default
    yes it is
  4. #4
    Smitty_82's Avatar
    Android Addict
    Posts
    ROM
    ICS / Stock
    Default
    OK, go into bootstrap recovery and hit "bootstrap recovery", there should just be a pop up that tells that recovery was bootstraped. You will then hit reboot recovery. This will restart your phone in recovery and you will be able to load the Apex zip from there. Let me know if you can get that far.
    pnico's Avatar
    Posts
    Global Posts
    398 Global Posts
    Default
    when I hit boostrap recovery it says the following..
    Error running exec commands :su-c/data/data/cp,.koushikdutta.droidxbootsrap/files/surunner.sh)
    working directory null and environment null
  6. #6
    Smitty_82's Avatar
    Android Addict
    Posts
    ROM
    ICS / Stock
    Default
    Do you still have your superuser icon?
    pnico's Avatar
    Posts
    Global Posts
    398 Global Posts
    Default
    yes
  8. Thread Author  Thread Author    #8
    pnico's Avatar
    Posts
    Global Posts
    398 Global Posts
    Default
    i have super user permissions..
  9. #9
    Smitty_82's Avatar
    Android Addict
    Posts
    ROM
    ICS / Stock
    Default
    OK, check to make sure that bootstrap is still listed on the superuser permissions. Also, did you us z4root to root?
  10. Thread Author  Thread Author    #10
    pnico's Avatar
    Posts
    Global Posts
    398 Global Posts
    Default
    grey icon
  11. Thread Author  Thread Author    #11
    pnico's Avatar
    Posts
    Global Posts
    398 Global Posts
    Default
    it isnt and yes z4root i tried to unroot with that too with no luck
  12. Thread Author  Thread Author    #12
    pnico's Avatar
    Posts
    Global Posts
    398 Global Posts
    Default
    it isnt
  13. #13
    Smitty_82's Avatar
    Android Addict
    Posts
    ROM
    ICS / Stock
    Default
    are you able to download anything from the market? Just asking cause I wasn't able to when this happened to me. Testing some ideas right now hang on. I'm at work right now.
  14. #14
    Smitty_82's Avatar
    Android Addict
    Posts
    ROM
    ICS / Stock
    Default
    Ok, go ahead and reroot with z4 to be on the safeside. That might have something to do with bootstrap not working.
  15. Thread Author  Thread Author    #15
    pnico's Avatar
    Posts
    Global Posts
    398 Global Posts
    Default
    yes i can dl from the market
  16. Thread Author  Thread Author    #16
    pnico's Avatar
    Posts
    Global Posts
    398 Global Posts
    Default
    rerooted with z4
  17. #17
    Smitty_82's Avatar
    Android Addict
    Posts
    ROM
    ICS / Stock
    Default
    OK, try bootstrap again
  18. Thread Author  Thread Author    #18
    pnico's Avatar
    Posts
    Global Posts
    398 Global Posts
    Default
    its rooting at the moment with z4
  19. #19
    Smitty_82's Avatar
    Android Addict
    Posts
    ROM
    ICS / Stock
    Default
    OK, let me know.
  20. Thread Author  Thread Author    #20
    pnico's Avatar
    Posts
    Global Posts
    398 Global Posts
    Default
    its still going..sorry still rooting
  21. #21
    Smitty_82's Avatar
    Android Addict
    Posts
    ROM
    ICS / Stock
    Default
    No prob, take your time. We'll get it working for you.
  22. Thread Author  Thread Author    #22
    pnico's Avatar
    Posts
    Global Posts
    398 Global Posts
    Default
    takes a while doesnt it?
  23. #23
    Smitty_82's Avatar
    Android Addict
    Posts
    ROM
    ICS / Stock
    Default
    LOL, it can.
  24. Thread Author  Thread Author    #24
    pnico's Avatar
    Posts
    Global Posts
    398 Global Posts
    Default
    what do you think I did? is my original os setup gone?
  25. #25
    Smitty_82's Avatar
    Android Addict
    Posts
    ROM
    ICS / Stock
    Default
    It wasn't really anything you did but flash a ROM that was having some bugs. It happens. I did the same thing but was able to flash back to the ApeX backup I had. Without a backup of your stock OS, it is gone. It can be recovered by flashing an SBF of the stock OS but it is easier to get you running on a good ROM and tackle the SBF down the road. ApeX is a solid ROM and will give you a better feel for a custom ROM.
