01-14-2011 01:46 PM
27 12
tools
  1. jonzey231@yahoo.com's Avatar
    Okay so I was installing a JRummy rom on my DroidX and I downloaded the rom. I rebooted and reformatted my data, cache, and system and then I went to install zip from sd card and couldnt find it so i assumed it failed. Well now that ive reformatted everything my phone wont boot into anything and I can only boot into system recovery. From there I tried to just update from a stock/signed update.zip and i keep getting an error. I tried to sbf but my computer wont recognize it at all.
    So now I'm sitting here with a droidx that wont boot past the Motorola logo.
    I'm sure its probably an easy fix, I just cant wrap my mind around how to do it. Someone please give me a hand.
    01-13-2011 01:03 PM
  2. rgray331975's Avatar
    Sounds like you need to install drivers from Motorola
    Sent from my DROIDX using Tapatalk
    01-13-2011 01:05 PM
  3. Johnly's Avatar
    Put that SD card in you comp, make sure the file is named "update" and try again. You have nandroid backups I assume?
    01-13-2011 01:07 PM
  4. jonzey231@yahoo.com's Avatar
    Yeah it's named 'update'. I didnt think about the drivers thing though, im reinstalling them now to see if that will work.
    01-13-2011 01:13 PM
  5. Johnly's Avatar
    Could be. Make sure you install both 32 and 64 bit versions (or if you know you OS, then that one)
    01-13-2011 01:23 PM
  6. jonzey231@yahoo.com's Avatar
    Yeah it's not working still. The computer wont recognize it while its at the M or in the system recovery.
    Any other suggestions?
    I tried an update again and this is the entire error.
    "Install from sdcard
    Finding update package
    Opening update package
    Verifying update package
    Installing update package
    file_getprop: failed to stat "/system/build.prop
    E:Error in /sdcard/update.zip
    (Status 7)
    Installation aborted"
    01-13-2011 01:23 PM
  7. xliderider's Avatar
    Do you have a micro sd card to usb adapter? That's what Johnly meant, to put the card in your computer and change the file name, if needed, to update.zip
    Make sure the file isn't named update.zip.zip
    01-13-2011 01:27 PM
  8. tntdroid's Avatar
    How did you dl it. In recovery go to install from zip. If you dl from net on your phone go to download folder and look for dx gummyjar. If you dl it from rom manager its in clockwork download droid2files. There was no need to rename it to anything.
    01-13-2011 01:29 PM
  9. Johnly's Avatar
    Are you running the computer as an administrator? How long is the M stuck?
    01-13-2011 01:30 PM
  10. xliderider's Avatar
    (Status 7)
    Did you select "Allow update.zip" before selecting "Install update.zip"?
    01-13-2011 01:30 PM
  11. tntdroid's Avatar
    When trying to run a sbf it needs to be in bootloader. Turn off phone. Hold power home and volume down till it shows bootloader. Hook to usb and open rsd.
    01-13-2011 01:31 PM
  12. jonzey231@yahoo.com's Avatar
    Yes I know how to put the zip on my card guys thats not the issue. I've been flashing and modding for over a year, I've got that down.
    xliderider: Yeah I'm using my adapter to put it on. And I don't see an option to "allow", just "apply sdcard:update.zip"
    tntdroid: theyre talking about making sure my update.zip file is name correctly, not the rom I downloaded through rom manager.
    johnly: It will sit at the logo until the battery dies.
    01-13-2011 01:40 PM
  13. jonzey231@yahoo.com's Avatar
    Okay, thanks. I forgot how to boot into the bootloader. I'll just do that and I'll be on my way.
    01-13-2011 01:41 PM
  14. Johnly's Avatar
    Let us know you got it jonzey231....we will all "feel" better : )
    01-13-2011 01:44 PM
  15. jonzey231@yahoo.com's Avatar
    Actually one more favor. I can't find a current sbf file anywhere. Someone want to give me a link, I'll keep looking in the meantime but I'll keep refreshing the tab to see if someone beats me to it.
    01-13-2011 01:46 PM
  16. jonzey231@yahoo.com's Avatar
    I found one that is system only, will that be alright?
    01-13-2011 01:48 PM
  17. xliderider's Avatar
    01-13-2011 01:50 PM
  18. jonzey231@yahoo.com's Avatar
    That's telling me I need to start out in bootstrap and I can't.
    01-13-2011 01:51 PM
  19. xliderider's Avatar
    Oops, sorry, yeah you will probably be ok just sbf'ing the system only for now.
    01-13-2011 01:54 PM
  20. jonzey231@yahoo.com's Avatar
    Tried it, and now I'm getting this error in RSD
    "Chipset type 50 is not supported"
    then once I press start I get...
    "Failed flashing process. Failed flashing process. Unable to receive values from INI file"
    01-13-2011 01:57 PM
  21. xliderider's Avatar
    What sbf system file are you flashing? 2.3.340, 2.3.320?
    01-13-2011 02:09 PM
  22. jonzey231@yahoo.com's Avatar
    I couldnt find a full sbf of either so im still trying to use 2.3.15. Its the one Ive used in the past then just updated ota. but now im back to square one, ive got it on the bootloader screen but my computer wont recognize my phone. I cant figure out why.
    01-13-2011 03:25 PM
  23. BreakingKayfabe's Avatar
    Flash .320 SBF and then use the patches that xliderider gave in bootstrapper
    once you're back up and running. I'm curious as to if you're actually in the
    bootloader or Moto recovery? When I SBF'd I got into the bootloader by
    turning the phone on and then holding the volume down button/camera button.
    Edit: It may have been volume up/camera button.
    01-13-2011 05:36 PM
  24. xliderider's Avatar
    Yeah, different bootloader versions in 315 and 320/340, that might be the source of that error you are getting. As Forever29 posted, try getting a copy of the 2.3.320 system sbf.
    01-13-2011 07:03 PM
  25. BreakingKayfabe's Avatar
    OP, if you need it I have the full. 320 sbf. Once installed all you need to flash are the patches on bootstrap.
    01-13-2011 08:17 PM
27 12
