Results 1 to 20 of 20
    Default Circle Battery Widget 1%
    I was reading around on some other forums, and circle battery widget now shows the battery percentage for the droid x in 1% intervals! There is some talk about how this is actually being accomplished, but so far its been pretty accurate for me.
  2. #2
    Default
    Interesting, it sure is...wonder how accurate it is?
    Storm 1 ----> Droid X
  3. #3
    tntdroid's Avatar
    Droiderator
    Posts
    Global Posts
    5,662 Global Posts
    ROM
    Bugless Nexus
    Default
    Link to where to get this? Market.
    Very cool! Now need to get working with roms.
    Sent from my DROIDX using Tapatalk
  4. #4
    tntdroid's Avatar
    Droiderator
    Posts
    Global Posts
    5,662 Global Posts
    ROM
    Bugless Nexus
    Default
    Very cool! Now need to get working with roms. Not sure how right it is. System still at 60 and this shows 56. When it was at 62 system was still 60. Ill try it a few days and see what happens.
  5. #5
    Default
    Quote Originally Posted by tntdroid View Post
    Samsung S3
    Time to feel the POWER...
  6. #6
    Default
    Quote Originally Posted by cobra302 View Post
    I installed the oem extended battery and after a night of charging the circle widget shows 99% not 100%. Anyone have the same thing happen?
  7. #7
    Default
    What is the difference between the free and paid versions of this? Is there any extra functionallity of the paid version?
    Thanks,
    Mark
    Kyo7135 - Treo600 - Treo650 - Treo 700 - BlackBerry 8800 - Blackberry 9000 - Droid - Storm 2 (failed Experiment) - Droid - Droid X - iPhone4S (waiting to come back to Android with HTC One or Samsung Galaxy S4)
  8. #8
    Default
    yep, 1% increments after the latest update. and seems to be accurate. and same here with only charging to 99% even when fully charged. but i dont care. thrilled to have an accurate battery %!
    Update: nm, its does charge all the way to 100% in the circle text.
    Default
    i noticed that the same on the charging, when plugged in, it showed 100, as soon as i unplugged it, it went to 99. i'm trying to determine what effect this will have on the battery as well. seeing the increments go down in 1% values as opposed to 10% is kinda freaky! LOL, i keep thinking my battery is draining super fast! which it still might be.....
  10. #10
    PsychicRefugee's Avatar
    Posts
    ROM
    Liberty GB v0.6
    Default
    I'm having no problems with Liberty 1.5 and showing it in Minimalistic Text. Maybe its just an estimation....
    Communique sent from a Droid X running 2.3.3 (Rooted & Deodexed [Leak]) with LauncherProPlus v.0.8.4.1 (Honeycomb themed).
  11. #11
    LMO
    LMO is offline
    LMO's Avatar
    Posts
    ROM
    ICS | Jellybean
    Default
    Hey guys, do you find that this runs your battery down any faster, being that it is most likely updating the status much more often? I would be very interested to know if it is a battery hog before I give it a try. ?
    ~ Droid RAZR MAXX, Stock rooted ICS
    ~ Xoom Wi-fi: Stock rooted JB
  12. #12
    Default
    Quote Originally Posted by LMO View Post
    have not noticed any difference at all as of yet. i cant imagine it making that much of a difference but we will see i guess.
  13. #13
    Arelunde's Avatar
    TECHFAN
    Posts
    Global Posts
    1,528 Global Posts
    Default
    Quote Originally Posted by wildman View Post
    This link doesn't work and a search of AppBrain (the computer door to Market) doesn't have anything listed for eBattery or eBattery Widget.
    Any additional info on this? Thanks in advance!
    Always learning ...
  14. #14
    kklier's Avatar
    Posts
    Global Posts
    155 Global Posts
    Default
    I was at 100% when I updated the widget this morning. I'm only at 82% now...for light usage.
  15. #15
    Default
    Quote Originally Posted by Arelunde View Post
    It's not "ebatterywidget"...it is Circle Battery Widget. (See the thread title above ).
    Just type "circle battery widget" in your market search blank and you will see it as option 1 & 3 depending on if you want to buy the donation version or not.
    "They don't think it be like it is, but it do." -Oscar Gamble
    Droid X (Liberty 3 v2.0)
    Droid Incredible (CM 7.2.0 RC1)
    Nook Color w/ 8GB N2A card
  16. #16
    Default
    Quote Originally Posted by kklier View Post
    What percentage does your regular method show you having? Let me guess...80%.
    It is probably just an estimation based on the time it has been running, not a true percentage. Honestly, does it really NEED to be 100% accurate? I don't know about you, but I put my phone on the charger every night when I sleep regardless of what any battery indicator shows & I haven't ran out of juice yet.
  17. #17
    Default
    I just installed and started playing with Minimalistic Text and it also is giving me a reading in 1% increments....
  18. #18
    Default
    I don't get why you say it doesn't work, it goes to the correct page for me when I click it, what are you getting when you click it?
    Samsung S3
  19. #19
    Default
    When I woke up this morning after my phone being plugged in all night mine was at 103% lol. Battery life seems the same for me.
  20. #20
    Default
    Mine got stuck on 62% last night. It didn't work again until I deleted it & restarted the widget.
