Results 1 to 6 of 6
- 03-13-2011, 10:28 PM
Thread Author #1
help unrooting with z4
hi guys i rooted my droid x using z4root. i tried unrooting using the unroot button on z4 but the super user is still there. i tried running some apps that requires root and says that i wasnt rooted. it appears that i am unrooted but how do i get rid of the super user icon? thanks in advance
- 03-14-2011, 12:04 AM #2
Touch and hold the icon then it will go to the home screen but do not let go. Drag it to the trash bin and hold it there until it says delete. Let go and it will let you delete it.
-Droid RAZR MAXX (Artic 2.2)
-Motorola Xoom (Rooted/Unlocked ICS)
-VZW 4510L LTE MiFi - 03-14-2011, 12:13 AM #3
This is actually a temporary fix because the app is still in device and as soon as you do a hard reset from stock restore Bootstrap and SuperUser will return... Here is my solution that I have been using that works perfectly..
I ended up figuring out the solution to remove the two apps that did not remove with factory reset after removing root:
Droid X Bootstrapper Complete Removal
* UNINSTALL the Recovery APK (Droid X Bootstrapper) in Settings, Applications
* Reboot
* Run "adb shell" or "Terminal Simulator"
* Run "su"
* Run "mount -o remount,rw /dev/block/mmcblk1p21 /system"
* Run "cp /system/bin/logwrapper.bin /system/bin/logwrapper"
* Reboot
SuperUser Complete Removal
* Root Device
* Install Root Explorer
* Browse to System >> Apps
* Delete all SuperUser.apk (My device had 2)
* Restart Device
* Goto Settings >> Privacy >> Factory Data Reset >> Reset Phone >> Erase Everything
After doing this I had a clean, unrooted, stock device ready for repair service.. NO SBF Required YAHHH!!!Samsung S3
Time to feel the POWER...Thanked by 4: - 03-14-2011, 08:35 PM
Thread Author #4
wow thanks guys...i will try it when i get off work
- 04-12-2011, 10:31 PM #5
Root Explorer is $4 got any free ones?
- 04-13-2011, 12:04 AM #6
Reply
