Results 1 to 6 of 6
    Default problems downloading angry birds
    I am having a problem downloading any of the Angry Birds games. It downloads and then says "installation unsuccessful" , reason code -18. Does anyone know how to fix this?
  2. #2
    Smitty_82's Avatar
    Android Addict
    Posts
    ROM
    ICS / Stock
    Default
    Make sure your sd card is mounted. Angry birds may install a chunk on your sd card by default. Are you using android or amazon market?
  3. #3
    Default
    Un-mount your sd card and try again; it should work if you are using the Google Market. If you want a better and more hassle free fix that also works with the Amazon store check post #28 here
    Default
    Quote Originally Posted by Smitty_82 View Post
    I was using the android market
  5. #5
    Default Re: problems downloading angry birds
    How can I download angry birds. My tablet downloads it then rejects installation. Happening repeatedly. I also want to download scrabble.:
  6. #6
    I have tried download after sd unmount. Not working.
