Whats going on my Android Central brethren, i dont post much here, i usually just lurk and plot evil things against all of you and the android platform in general. Today im a changed man tho, im in need of help.
I happened to drop my phone into a water source, dont ask, seriously you dont want to know. I grabbed it out after seriously a second, maybe less. I was in the process retrieving the moment i saw it start to slide towards its possible grave.
So i took it out, almost broke the back off trying to get the battery out as fast as possible (I have a loose back door cover so it actually was quite easy) and i immediatly started drying everything off possible... I got some paper in the headphone jack, blotted at the usb and hdmi and speaker grill. No water even got on the battery or in the back door, which surprised me, cause seriously the back door slides off alllllllllllllllllllll theeeeeeeeeeee timeeeeeee....
tl:dr
water damage. Took battery out right away
My question is...what should i do now? Anyone got some pro tips for me? Guide to take my phone apart to make sure i got the basic internals dried (nothing to complicated is necessary). I plan on letting it sit in my window sill for a few hours right now cause its a hot day outside and i figure some internal cooking would help some evaporation...
thanks..any advice or insight i welcomed. No haters needed.
Update: I see water moisture on the inside of the camera lens cover.
tl:dr
