1. tyczj's Avatar
    I just got a droid x the other day rooted and flashed the leaked OTA (did not wipe) update for it but Gmail it terrible slow to let me know when I get a message where as i can have my OG droid that i now use for developing and it will let me know right away. The X does not get it until anywhere from 15-45min later which is not good for me.
    anyone else seeing this problem?
    I also notice that the phone is constantly syncing as per the sync icon in the notification bar is always there, maybe that has something to do with it?
    04-20-2011 11:14 AM
  2. ottscay's Avatar
    The sync icon issue means you need to do a wipe. That may also clear up whatever issues you're having with Gmail, although I never experienced that before or after the wipe, so I can't say for sure.
    04-20-2011 12:19 PM
  3. diverbelow's Avatar
    I also had issues with my Gmail. I was able to get emails, and when I delete emails through my X, they will not be either deleted or read. What I found out last night, there is an Gmail.apk in /system/app that is old. So I added .bak to that file using Root Explorer, installed Gmail through the market and my Gmail was working great. My X rebooted it self and once my phone was fully up and loaded, I kept getting FC for the Gmail app I just installed. Using Root Explorer, I copied the gmail app from the market at /data/app to /system/app and renamed it to Gmail.apk, rebooted and now I have no more issues with Gmail.
    04-20-2011 01:00 PM
  4. tyczj's Avatar
    Hmm that solution is interesting not only because it worked but because the versions appear the same 2.3.4.1 and when I went to the market it would.not let me uninstall it like I normally could on my other phone. I had to use my girlfriends phone to send the application over to mine, then I installed it just like I would any other app from my sd card and it gave me a warning about this is a system application that I am going to override. I then installed it and it seems to be working normally now, I just got a bunch of emails. I just find it weird that it is the save version and it does not act the same as the one through the market that I couldnt even uninstall
    04-20-2011 05:45 PM
