Results 1 to 11 of 11
    wormeyman's Avatar
    Posts
    Global Posts
    237 Global Posts
    ROM
    Gingerbread 2.3.3 rooted
    Question How do i turn of the notification LED?
    I don't ever use the notification LED and sometimes it wakes my wife up at night which is not a good thing. Is there an app that i can run or a setting to turn off all led notifications?
    I'm on the 2.3.3 leak version 4.5.573
    The other option is to get a nexus S but i have 14 months left in my verizon contract
  2. #2
    newskate9's Avatar
    Posts
    Global Posts
    40 Global Posts
    Default
    Well........... if that's the only reason you want to turn them off. Wouldn't it be easier to turn your phone over?
    wormeyman's Avatar
    Posts
    Global Posts
    237 Global Posts
    ROM
    Default
    Quote Originally Posted by newskate9 View Post
    I turn my phone over (simple solutions usually are the best) but sometimes i forget and i was wondering if this is possible?
  4. #4
    jerseyboy357's Avatar
    Posts
    ROM
    Liquid Smooth JB Beta 2
    Default
    You must have a bright LED to wake someone up with it. First Ive heard of that. And hopefully you find another solution before you give up the phone. Try turning off any status bar notifications.
    I am now in the Galaxy Nexus member's club as of Aug 2012. Late to the party, but well before it shuts down!
  5. #5
    Default
    Quote Originally Posted by wormeyman View Post
    There are several apps...1 that I use, Light Flow allows you to designate notification for many different apps (SMS, Email, etc), the color of the LED you want to use, the duration it flashes, the speed of the flash, etc.
    It seems to work great. There is a free version & paid version in App Market.
  6. #6
    Default
    You could setup a profile with Tasker to turn off the LED notifications in each of your apps automatically at a certain time & then back on in the morning.
    wormeyman's Avatar
    Posts
    Global Posts
    237 Global Posts
    ROM
    Talking
    Quote Originally Posted by Sailmaker View Post
    I tried light flow and it looks like i can turn off LED notifications from 6pm to 6am which is probably what i want i'll try the free version for a while and then buy the paid version to support the dev.
  8. #8
    Arelunde's Avatar
    TECHFAN
    Posts
    Global Posts
    1,536 Global Posts
    Default
    I have a little basket, just bigger than the X, with a (clean, dry) folded washcloth in it. At night, I put the X face down, into the basket at night, plug it in to the charger, and cover it with the other side of the washcloth. It has its own little "bed" I'm ashamed to say. But, it's part of the family! Works great.
    Always learning ...
  9. #9
    Default WhoIsIt
    WhoIsIt is a market app which allows you to set up profiles and takes over the notification system for text/email. my sound and LED notifications go off for the night when i put the phone in my bedside dock (Tasker works with WhoIsIt to change the profile when the dock is detected), UNLESS i get a call from one of a few specific numbers/people. worth a look.
  10. #10
    Posts
    ROM
    Default
    Quote Originally Posted by Arelunde View Post
    Don't be ashamed Are,lol I have named my phone and treat it nicer and safer than some people I'm paid to protect,lol.
  11. #11
    Default Re: How do i turn of the notification LED?
    Lightflow, noled still allow blinks with everything off. Tasker is just too complicated. I don't want to root just for this. My old palm pre had the issue till someone wrote a simple patch that killed the led always. I don't need notifications cause my phone is glued to my hand lol. I want all my led notifications off, so I can echo this sentiment. And flipping or covering a $600 USD gadgdet seems rather silly, esp. If you use a dock, lol
