Results 1 to 7 of 7
    Burner50's Avatar
    Posts
    Global Posts
    23 Global Posts
    Default Screen Problems
    I got my Droid X in the end of march.
    Today, after the screen had been lit up for a few minutes I noticed it started flickering...
    Now the screenshows a black screen with a random sprinkling of various shades of grey pixels.... except for the top few rows... they still work fine.
    I noticed that If I keep my phone "Asleep" for a few minutes, it works fine for a few minutes...
    The closest verizon store is 100 miles away. I was told that I have a year warranty, but I would rather not have the device replaced... any ideas on a potential solution?
  2. #2
    dacp283's Avatar
    Posts
    Global Posts
    163 Global Posts
    Default
    Quote Originally Posted by Burner50 View Post
    don't know about that but I'm thinking replacement might be your only option
    Sent from my DROIDX using Tapatalk
  3. #3
    cae2685's Avatar
    Posts
    Global Posts
    727 Global Posts
    ROM
    Stock
    Default
    I seem to remember a problem with the screens around the time the DX launched, but I don't remember the details. Either way, 800-922-0204 is VZ customer service, they should be able to send you a new one. Well, it's probably gonna be "certified pre-owned" but there's not a lot you can do about that. Either way, they'll send you a replacement.
    Droid X
    Samsung Galaxy S3 - CM10
  4. #4
    dacp283's Avatar
    Posts
    Global Posts
    163 Global Posts
    Default
    Quote Originally Posted by cae2685 View Post
    Nothing wrong with certified pre owned lol. My original X wouldn't over clock past 1.15 ghz without crashing. I've had this one up to 1.4 with the only issue being heat especially in the otterbox. But its stable now at low voltage 1.35 using droid overclock
    Burner50's Avatar
    Posts
    Global Posts
    23 Global Posts
    Default
    Next question:
    Phone is rooted with Z4 and has wireless tether for superusers installed...
    Cant see what I'm doing to get those off there... What consequences am I looking at with verizon? Will VZ even look at something like that?
  6. #6
    Default
    Next question:
    If you can't see anything on the screen then neither will they. Most likely they will just SBF it and if that doesn't work probably cannibalize it for parts. But you could get it into the bootloader screen and SBF it yourself if you want. Not much that you actually have to see to be able to SBF from RSD lite.
    Thanked by:
  7. #7
    cae2685's Avatar
    Posts
    Global Posts
    727 Global Posts
    ROM
    Stock
    Default
    I agree with sage. Rsd won't work unless you're at a specific screen, and requires no screen interaction from the user... It's all pc based. might as well.
    Sent via Tapatalk
    Droid X
