Results 1 to 3 of 3
    Angry Stock X acting wierd, help!
    1. sometimes the camera screen blinks when I try to take pictures.
    2. When browsing my apps it randomly jumps back to the home screen.
    3. Viewing any movie, from any player, streaming (Netflix) or local it pauses after 10-60 seconds. I can hit play again and keep watching as if nothing happened.
    I saw someone having similar issues here:
    Any ideas?
  2. #2
    Default
    it sounds like you just have typical DX glitches in the software. i'd recommend either a stock wipe or wait for GB this friday and see if that fixes your issues.
    Default
    I just installed SBF. Hopefully Gingerbread helps, thanks.
