1. NBDroid's Avatar
    I have this problem with ADW where my dock bar will randomly disappear. It's not HIDING, it literally disappears. The only way to get it back is to restart my phone.
    I recently updated with GB and I wanted to play around with the stock desktop, or possibly a different launcher program. Do I have to uninstall ADW or is there a way to turn it off? And are there any recommendations for a "better" launcher program than ADW?
    Thanks Android peeps!
    06-06-2011 02:03 PM
  2. wildman's Avatar
    Install Launcher Switcher from https://market.android.com/details?i...=search_result and then you can switch from all installed launchers installed on the device...
    NBDroid and mlynchmob16 like this.
    06-06-2011 02:29 PM
  3. cyberdalek's Avatar
    You can also long press on the desktop and bring up the launcher actions and place an open/close dockbar icon on your desktop. It's a pain but it is a fix that doesn't involve shutting down phone. I have the same issue on occasion.
    06-08-2011 11:48 AM
