My LEDs work just great in gmail & missed call. I'm using LightFlow and it works with GB.Handcent works with the latest update. No Gmail or missed call LED'S. I really miss those.
The problem is: When an email or sms is received, the screen wakes up and THAT is when the led's become inoperative. If you could keep the screen from waking up, the led's would work as designed.
I did that...no luck. Is there a way to keep the screen from waking up when a call or SMS comes in?
Not be an a$$, but you don't have an LED problem then, you have a screen wake problem. Can you change the alert settings in your email and SMS programs?
I downloaded Light Flow to my wife's X this morning and found that it wouldn't work after I rebooted either and think I found out what the problem is. When you first open the app it asks you if you want to allow it in your Accessibility settings. Even if you do, you still have to go in there on your own and turn it on (it may be already checked so just uncheck it, then check it again). After doing this it worked flawlessly for her.
