Results 1 to 7 of 7
    Default Problems with SD card
    Since I've OTA updated to gingerbread, I have had the hardest time getting transfers to actually work properly to my micro sd card. I've tried setting it to PC mode, Mass storage, and the windows media sync, but every one of them either just don't plain work , or after a few minutes become unresponsive. I've already reformatted the card. Not sure what else to do. Maybe uninstall and reinstall the drivers? How exactly do I go about doing that on Windows Vista? Thanks.
  2. #2
    gordol's Avatar
    Posts
    Global Posts
    1,154 Global Posts
    Carrier
    Stock GB 2.3.4
    Default
    If you haven't done this yet, pull the card from the Droid and plug it into the PC directly. You can get card readers and adapters as needed at places like Best Buy, and Staples. This will tell you if the problem is the Droid or the card.
    I've had no such problem since updating to Gingerbread.
  3. #3
    Jihoonie's Avatar
    Posts
    Global Posts
    35 Global Posts
    Default
    I've had the same problem where my sd card pops up on my computer, but then disappears. It will do this over and over again. I plugged the sd card directly into my computer and it didn't do this. So, I assume it's the phone after the GB 2.3.3 update. Running rooted version btw.
    I also notice that my camera will often malfunction. When trying to access my camera I get a message that this service is currently unavailable. Not sure what that's all about, but I assume it has something to do with the SD card issue.
  4. #4
    gordol's Avatar
    Posts
    Global Posts
    1,154 Global Posts
    Carrier
    Stock GB 2.3.4
    Default
    Quote Originally Posted by Jihoonie View Post
    From what I've been reading in the forums, there is no root for Gingerbread at this time, and CM7 specifically lists that the camera does not work... If you restore to stock, does the problem go away?
  5. #5
    Default
    Try uninstalling drivers and reinstalling, if you have Motorola Driver Installer.exe installed you can click Clean and Install from app...
  6. #6
    Default
    Have a look over here...
    I think it is a widespread issue.
    http://forum.androidcentral.com/moto...highlight=card
    Default
    Well, i reinstalled the drivers. Totally wiped off every trace of the drivers and software from the computer. Reinstalled, and it seems to be working okay so far. Still slow at times, but not as bad. I'll take it out, put it in an adapter, plug it in to a computer and see what that does. Hopefully it clears up. Thanks for the advise so far.
