1. wcsoccerboy828's Avatar
    I rooted my DX2 a few weeks ago and just today decided to attempt flashing a ROM to it. I downloaded the Liberty 3 ROM for the X2 and everything that I found I needed at this site: DX 2 LIBERTY 3 v1.0
    I followed the directions down to the point where it said, "Wipe Data/Factory ResetWipe Cache" and I wasn't sure if I should do that. I got called AFK and when I came back, I continued, skipping that step and proceeding with the flash. I installed the zip file and everything, it was successful. Then I clicked reboot. I waited between 10 and 15 minutes and all that had happened was it had looped through the boot screen (the one following the red M). I got scared and did a battery pull and went to wipe the data. I wiped the cache and decided to try to boot. Now I cannot even get it passed the red M. Help me - I don't want to brick. I'm in the process of downloading the SBF, but I don't have the quickest internet connection and it says 31 minutes left. I downloaded the RSDLite 5.3.1. and 5.1 Drivers found here: http://www.droid-life.com/2011/06/25...-for-download/ and the SBF file found here:Help My Dx2 stuck on Bootscreen!!!
    Are these the correct files to be using? If not, what do I need? I'm not the best with technology, but I have some experience with it and can follow directions well. Any help is greatly appreciated.
    01-22-2012 03:37 PM
  2. maggard5's Avatar
    Use this link and you will be fine. Any questions, just ask and I will try to help you.
    wcsoccerboy828 likes this.
    01-22-2012 04:26 PM
  3. wcsoccerboy828's Avatar
    Thanks - I got it working again.
    01-22-2012 05:11 PM
  4. maggard5's Avatar
    Good to hear. If you are looking for a rom to flash, try cm7.
    Sent from my cm7dx2 using Tapatalk
    01-22-2012 05:25 PM
