Results 1 to 4 of 4
    Default problem with cm10 installation
    Have tried to install cm10 several times, keep getting this error. any help available??
    Set_perm: some changes failed
    E:Error in/sdcard/cm-10=20121007-UNOFFICIAL-daytona.zip
    (Status 7) Installation Aborted
  2. #2
    MunkinDrunky's Avatar
    Posts
    ROM
    DX2:eclipse2.2 Fasn8:ICS
    Default Re: problem with cm10 installation
    Are you coming from an aosp rom? Im not any kind of expert, in fact I can only guess if you don't have the patched bootstrap recovery for aosp you might have problems.
  3. #3
    bregga's Avatar
    Posts
    ROM
    [ROM][ALPHA] quattrimus
    I always sbf back to 2.3.4 before installing a cm 10 rom on mine and have not had any problems.
    If you need help sbf'ing your phone let us know we can point ya to the how to's.
  4. #4
    I tried running the cm10 installation and it succeed but when it comes up the keyboard(AOSP) keeps crashing so i don't have a keyboard so i cant log in to Google or Google play so i can't install any apps. I can't get the cm7 recovery loaded because i have no keyboard. Any Suggestions?
    Thanked by:
    mrmoto
  1. Problem with the pre-installed weather widget
    By adamjac78 in forum Motorola Droid X
    Last Post: 03-02-2012, 07:12 AM
  2. Problem with Clockwork mod installation
    By dizpers in forum Motorola Droid
    Last Post: 06-23-2011, 08:20 PM
  3. Anyone having problems with Google Maps 5.3.1 install?
    By tmeader in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 05-06-2011, 01:41 PM
  4. Problems with swype since installing gingerbread...
    By goonieboy in forum Google / HTC Nexus One
    Last Post: 02-25-2011, 06:07 PM
  5. Problem with Droid Incredible installing apps from market and sd card
    By dbuckley31984 in forum Verizon Droid Incredible
    Last Post: 01-15-2011, 11:46 AM
