1. Jarvisha Hunter's Avatar
    How do i flash my phone back to verizon wireless?
    02-25-2013 12:28 PM
  2. sd_shadow's Avatar
    back from what?
    Sent from my XT862 using Android Central Forums
    03-03-2013 08:40 AM
  3. justagirl_82's Avatar
    Is it possible to reflash a verizon phone back? It was flashed to yourwireless world
    06-21-2013 11:13 AM
  4. sd_shadow's Avatar
    yes just Flash a SBF/ (stock rom) Using RSD Lite
    06-21-2013 11:23 AM
  5. juanito623's Avatar
    i got a lg intuition that was flashed to cricket to work with there signal and 3g but i have verizon as my carrier i insert my sim card and it works but only stays on 3g service and drops connection is there a way to flash it back to verizon ??
    06-24-2013 02:49 PM
  6. sd_shadow's Avatar
    you need to find a section for for phone, at least LG
    Motorola's are very different
    Sent from my Amazon Kindle Fire using Tapatalk 2
    06-24-2013 03:03 PM
  7. juanito623's Avatar
    OK THANKS
    06-24-2013 03:42 PM
  8. tsmyb's Avatar
    Can I flash my droid razr back to Verizon from page plus and if so how do I get it done? Thank You
    03-02-2014 12:25 PM
  9. sd_shadow's Avatar
    Yes you can flash your Droid Razr using RSD Lite_v6.1.4 and stock Firmware from here Motorola Firmwares
    Download the correct firmware
    see menu>settings>about phone>system version should be something like Blur_Version.98.72.165.XT912.Verizon.en.US
    you can not downgrade android version ie 4.1.2 to 4.0.4
    you can follow my how to use rsd lite
    if your not sure, post your current system version
    03-02-2014 12:55 PM
  10. sd_shadow's Avatar
    This is a Droid X2 section so if you have more questions, please post in the razr section.
    Sent from my XT862 using Tapatalk
    03-03-2014 02:23 AM
  1. need to flash my X back to verizon
    By chvz80 in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 03-14-2015, 06:38 PM
  2. Have I put my phone back to stock? n00b question NEED HELP NOW!!!
    By TheRidge in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 09-16-2011, 05:03 PM
  3. How do I return my phone back to stock?
    By DirtMcGirt in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 05-12-2011, 10:47 AM
  4. Need to Flash phone back to verizon
    By Astout in forum Verizon Fascinate
    Last Post: 03-29-2011, 05:02 PM
  5. Can someone help me to flash my hero back to stock
    By saiyantwin in forum HTC Hero
    Last Post: 04-17-2010, 02:02 AM
