Results 1 to 9 of 9
    1buda's Avatar
    Posts
    Global Posts
    319 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Battery life
    Just picked up a droid X2 a few days ago, and the battery is draining to about half full in a days time. Would it be wise to upgrade to a larger battery?
  2. #2
    Bendroid55's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery life
    Most of us would be ecstatic to have 50% left at the end of the day.
  3. #3
    LHKJohn's Avatar
    Posts
    Global Posts
    192 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Bendroid55 View Post
    This!
    Sent from my DROID X2 using Tapatalk
    1buda's Avatar
    Posts
    Global Posts
    319 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So what's the battery life are you guys getting?
  5. #5
    Bendroid55's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    On the weekend I can usually eke out the day on one charge.
    I have several spare batteries laying around. At work where the Verizon coverage is awful, it's not uncommon for me to go through 3 in one day.
  6. #6
    Stagger0's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Depending where I am I can get 13-16 hours. 11 when I take a 45 min drive on the highway. This things battery life is pretty good.
  7. #7
    schaferan's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM7DX2 (beta)
    My battery life is pretty good. Way better than my wife's DInc and pretty comparable to my OG Droid, maybe even a little better. When I've been in areas where I'm going in and out of coverage frequently it does drain the battery though. I will say that when I got the phone new it did take a few cycles for the battery to reach its full life. I bought a back-up battery for when I'm using my phone heavily (gaming) and noticed the same issue. Basically, give your battery a hand full of cycles before you make up your mind. My battery lasts way longer now than it did when I first got it and I have a ton more apps now as well. Overall, I'm pretty happy with the battery life.
  8. #8
    reallyte's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Get juice defender, I go 2-3 days between charges.
  9. #9
    LHKJohn's Avatar
    Posts
    Global Posts
    192 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I can barely get through a 10 hour work day using some navigation, email, tapatalk, and facebook.
